KenJax Tree
¯\_(ツ)_/¯
- 3:35 AM
- Dec 31, 2015
- Over there
Why mix oils and not just use one or the other?
I believe that's the tcw3 stuff. Keith can confirm.I run this and this only i usually swing by wally world once a month to get a case of it.
mix this 8oz bottle to two gallons of 90 octane ethanol free. Has a nice blue color too it does smoke in equipment when they are cold but after they warm up the smoke is gone. Can't beat the price either 1.23 per bottle, This is air cooled oil not tcw3
Ya thats what I saw tooThe tcw3 stuff says tcw3 on the bottle.
What works best in your 562XP so far?Ya thats what I saw too
I have no idea man as I have only ran kl200 original Klotz. From what Im seeing is 1 oil will combust different in autotune vs mtronics vs carb saws from another oil. It depends on loads IMO but Redbull is the one thats went the extra mile on oil testing. What may work in 1 saw may act differently in another and I say that because Redbulls 661 burn kl200 differently than my 562xp does but then again not enough run time on my end to give an opinion. Any FD rated air cooled oil should suffice thoughWhat works best in your 562XP so far?
supertech says high performance so im sure it will work fine in either auto tune or m tronic saws.I have no idea man as I have only ran kl200 original Klotz. From what Im seeing is 1 oil will combust different in autotune vs mtronics vs carb saws from another oil. It depends on loads IMO but Redbull is the one thats went the extra mile on oil testing. What may work in 1 saw may act differently in another and I say that because Redbulls 661 burn kl200 differently than my 562xp does but then again not enough run time on my end to give an opinion. Any FD rated air cooled oil should suffice though
I have no idea Jake as I have only used silver bottle full synthetic supertech and liked it in ope. It looks from the MSDS to be Citgo distributed. Ill continue to use kl200 in my saws as I have seen no need to change . Seems my new 562xp autotune is rich and alil wet at 40to1 with kl200 compared to my regular carb saws but more time will tellsupertech says high performance so im sure it will work fine in either auto tune or m tronic saws.
I recently seen some one post that the Australian manual for the 562 says to run 33:1I have no idea Jake as I have only used silver bottle full synthetic supertech and liked it in ope. It looks from the MSDS to be Citgo distributed. Ill continue to use kl200 in my saws as I have seen no need to change . Seems my new 562xp autotune is rich and alil wet at 40to1 with kl200 compared to my regular carb saws but more time will tell
Hadnt seen that but I didnt read the manual either!! Lol!!I recently seen some one post that the Australian manual for the 562 says to run 33:1
I thought it was kind of interesting .
i have confirmed that according to the husqvarna australia site under the 555,560,562 manual.Hadn't seen that but I didn't read the manual either!! Lol!!
