stihl sawing
2:02 PM
Arkysaw
I've got an old homelite weedeater I dug out of the trash many years ago and keep it at this place I mow and trim all summer, that way I don't have to haul the stihls there. It has been running on some stuff I bought at k mart for years now. I bought several bottles of it on clearance. Also i'll be honest and say I don't even mix it. I pour the gas in and add the oil to the tank and shake a little. I have no idea what ratio it gets each time. I really didn't care if it blew up when I started doing this years ago, but it won't die. still runs fine. sometimes I get it a little heavy and it smokes more. Now with that being said I would never do my stihls that way.
stihl saws
You can always justify another saw.
3:02 PM
Virginia
I'm sure most of us have "mixed" oil this way at some point. When you only have a little gas /oil left and have to get done, you do what you have to. I try to judge it by color.
junkman
Crush it
12:02 PM
pacific northwest
661 amsoil 32:1
dual port muffler with wide weave screens in
after another 2 tanks. ...screens in, seem to raise the temp a bit?
I experienced the same thing going from bike oil to the saber till i retuned for the saber. Choking the saw down creates heat which will make a cleaner muffler can at the same tune.
bwalker
3:02 PM
Montana
Wow that is interesting and raises a few questions.
Yes it does. I question how finely M-Tronic tunes give the differance in results from just a screen change.
On the other hand maybe you reach a tiping point with a modded muffler where the engine just won't run clean. Perhaps the lack of a screen drove the saw over this point.
bwalker
3:02 PM
Montana
Yes like how accurate is the auto tune between oil swaps ??
I've had this concern all along in regards to M-tronic. The autotune system Husky uses on the other hand works very well. I have switched from 40:1 to 20:1 and noted no chang at all in regards to idle rpm, or feel in the cut. The engine didn't even smoke anymore at idle on 20:1.
CR500
3:02 PM
Western NY
any specific way to calibrate for bar differences, other than the 90 second idle?
stihl saws
3:02 PM
Virginia
No posts in the oil thread today? What is wrong with you guys? Which one was best, the silver bottles confuse
me?
stihl saws
3:02 PM
Virginia
The big one has a spout, so I guess it's for oiling tools and stuff.
jmssaws
Banneded
2:02 PM
I have ran 3 gallons of blue oil so far.
I ported a 660 the other day and after less than a tank I pulled the cylinder to change timing and the new piston was completely black and dry.
I have never seen anything like it,with the other oil i used it would be just a slight wash pattern.
Should it be completely black that fast?
jmssaws
Banneded
2:02 PM
It took a half tank of gas to black the new piston. Is that right cause it sure don't seem right
