CR500
- 7:44 AM
- Jan 31, 2016
- Western NY
bar and chain is upside down ya know.....
it helps it cut faster it is stihl ya know.bar and chain is upside down ya know.....
were did you get the oil and i like the colorGood combination right here. The throttle response seem to be more crisp. Wasn't cutting any firewood, I was doing yard work.
I got the oil from @Redbull661 But I'm pretty sure I bought all he had. I'm pretty sure that Mike @mdavlee is selling some. I use Radical Racin' Raspberrywere did you get the oil and i like the color
and what scent did you use?
doesn't caterpillar make dye to put in fluid? like oil or fuel.Yep. I've got some of the undyed stuff
I was just about to say that..... @jmssaws where do you get your dye?doesn't caterpillar make dye to put in fluid? like oil or fuel.
Stuff is expensive last I checkedI was just about to say that..... @jmssaws where do you get your dye?
Its like $50 for 8ozStuff is expensive last I checked
Sent from my non internal combustion device.
52$ per bottleStuff is expensive last I checked
I think Jason said it will only take a drop per gallonIts like $50 for 8oz
1998:1 i thinkIts says 8oz will dye 125 gallons
And its only $3 for a sharpie to mark you 2 stroke gas can.Its like $50 for 8oz
