the GOAT
87, k2 40:1
- 11:37 PM
- Dec 23, 2015
- Mikes from Maine
How much time did y'all save today with the perfect oil/ratio?
Is the valvoline specific ope or bike oil ? And color of it ?I just finished up a gallon of valvoline at 32:1 with 91 efree.
Saws ran and tuned perfect on it. I'd say it's good oil.
Back to benol at 40:1 now
Most of you guys jump to conclusions based on a poor understanding of what's going on, limited expiereance, poor test data or all of the above.I agree. Alota folks here that work on saws and tested all these oils and have seen the difference internally in their saws are now using the same oil . Wonder why that is? Alota folks jumpin around between oils and say oil is oil and they all work and all they really know is it hasnt burn my saw up yet but they havent seen the bottom or topend to actually know what is goin on in their saw.
All you can do is disagree.Most of you guys jump to conclusions based on a poor understanding of what's going on, limited expiereance, poor test data or all of the above.
I posted plenty of pics on the other site. I'll not be tearing a saw down to check for something that's apparent by looking through the plug oil or from be aware of oil ratios effect on residual oil.All you can do is disagree.
Let's see the inside of your saws if you can take one apart
That's been my expiereance.I build saws for loggers. I don't think it matters what your cutting.
Most loggers abuse and use the cheapest oil they can.
Most here run Walmart oil without issue.
I'm also a logger myself
Sounds like farmers....I build saws for loggers. I don't think it matters what your cutting.
Was wondering how you went through a gallon of mix so fast ,your job explains it now . only time i go through a lot is when milling a lot . at 40 to 1, 16 oz per 5 gallon can 1 gallon of oil is 8 gallons of mixed fuel ,that's a lot to run through a saw in little time even milling a lot .I build saws for loggers. I don't think it matters what your cutting.
I port a saw almost every day and constantly have to run a saw. I put a couple tanks through a couple saws every day. I rarely cut timber anymore,I port full time and have for a very long time.Was wondering how you went through a gallon of mix so fast ,your job explains it now . only time i go through a lot is when milling a lot . at 40 to 1, 16 oz per 5 gallon can 1 gallon of oil is 8 gallons of mixed fuel ,that's a lot to run through a saw in little time even milling a lot .
I spoke with a logger who told me he likes the lucas That's why I'm trying it out for nowYou guys need to ask some loggers what they use, The guys that run them 8 to 10 hours a day and abuse the heck out of them. Pretty sure whatever they buy it's in drums or gallon jugs, not in little bottles like most of us buy. These guys don't cut cookies.
Is the Valvoline sold at Walmart and auto parts store, guess I don't remember seeing their 2 stroke oilI port a saw almost every day and constantly have to run a saw. I put a couple tanks through a couple saws every day. I rarely cut timber anymore,I port full time and have for a very long time.
I see what poor oil at 50:1 does every day.
I've got most of my local customers switched to Walmart oil at 40:1 and I like what they look like inside. It's very good oil.
For 4.99 a quart I'll try changing them over to valvoline. I ran it to see how it was before telling them to switch, it's very good oil and very cheap. Bad gas and orange stihl are what kill the dead saws I see but even that is rare,saws are extremely tough.
Bah humbug!!Most of you guys jump to conclusions based on a poor understanding of what's going on, limited expiereance, poor test data or all of the above.
Here as well. Hedgerow turned me on to it. 40:1 for work, 32:1 for play.I spoke with a logger who told me he likes the lucas That's why I'm trying it out for now
