junkman
Crush it
- 4:48 PM
- Jan 3, 2016
- pacific northwest
Boat oil
I'm kind of glad I ran across this now. I've been running 40:1 (I try to get at least 3.2 oz of oil per gallon of gas) at the advice on this board to keep the heat down on my 395xp when milling, but I'm starting to think the real change was just me finally adjusting the carb to run a bit more rich. I'm not a smart guy, but wouldn't adding more oil to the gas actually make the saw run leaner, if not tuned? I only have one gas can for premix, right now, so I just tuned all my saws to run on the 40:1 mix. Just to be safe I'm also running two cycle oil for racing dirtbikes, but maybe that's not necessary? I'm thinking about changing over to a plant based 2t oil from a local-ish distributor. They sent me a sample, but it's only enough for a 50:1 on a full gallon of gas...
I read, maybe even here somewhere, that boat motors run cooler and the boat oil doesn't do as well in the hotter conditions of a chainsaw. Sounds like an urban legend, but I've been wrong before.Why does boat oil get a bad rap when run in saws?
Is this what you use normally also?Milling is different.
If I was milling with a chainsaw, I'd be using Belray H1R at 32:1
I thought there was issues with dominator and corrosion/protection issues when sitting? Or was I misinformed?
No. I use Amsoil Dominator at 40:1.Is this what you use normally also?
You used to be a Yamalube 40:1 guy sir.
Has anyone tried Maxima Castor 927?
That is surprising given the reputation. Are synthetic oils better? I've only used the B&S little bottle with the measuring cup built in, boat 2t oil, and Maxima Super M. Is the only way to see how well they work to take apart the engine? I get that this thread has covered all of that, but it is also nearly 900 pages long.Yes. Not one of my favorite oils.
Yup , a twenty minute conversation can be a real perception change , agreed.
Have the results been published in public, perhaps in a closed thread?
