12:10 PM
Looks alil gooey and hot!!! Lol!! Klotz Super?
I can't remember the oil, but it was a bean oil of some brand. Personally, I just bought another gallon of 2R. It's good clean burning oil, that works well in all the engines I build.
Treemonkey turned me on to some Schaeffer Oil, so I plan to try it in the AT saws to see if they tolerate it as well as they do the 2R.
Randy u have probably seen more pistons than most of us here. Is carbon of the hard dry nature normal on the piston top?
Yes. I think seeing a clean piston top is indicative of a oil that is not burning, and is washing the piston. Same for the exhaust port.......should be black with hard dull carbon.
Keith Gandy
Maxima K2 40:1 87 Pump Gas
12:10 PM
Provencal, Louisiana
I concur. I have to say Redbulls 661 looks great with that Schaffers
Ron660
12:10 PM
NW Louisiana
Get your dyno tuned up and I'll send a 66 with klotz and you with 800 and we'll see what oil makes the most power.
I seriously doubt there will be a noticeable difference in HP comparing oils. If you wanted to compare oils on a dyno, you'd need to use the same saw to limit variables.
