- 2:29 PM
- Feb 5, 2016
- Here & Now
Husky Xp is crap. Just a joke. I've used it nothing blew. Don't know much bout any of the oils
My take on it is, lower flash point oils get lit up sooner,What's the deal with flashpoints? Higher the better? Not sure how to interpret those figures.
Klotz kl200, echo red armor, yamalube 2r , dolmar/makita/poulan synthetic would be safe choices . Stihl Ultra being one of my least favoritesTrying to get Red Armor, that I do understand to be a good oil.
Wouldn't mind waiting on it to come, but its not available locally.
So what has one to do, earlier I got a bottle of Husky XP to try,
a local man who uses huskies says it great, will know in due course.
All I need now is for someone to say its crap, and I will have another ornament.
A higher flash point like the Motul 800t in normal wood cutting and a ratio tuned rich say 32to1 is difficult to combust completely. Takes a heavy load and higher temps such as milling to completely combust and form a good carbon crown with transferMy take on it is, lower flash point oils get lit up sooner,
this gives them more tiem to burn clean, leaving no ash but probably
a hotter saw which also helps a cat to do its work, but that kind of heat
is not what I like.
The good synthetic oils have higher flash points, and that because syntheic
oil can work at higher tempratures, this results in these oils not getting lit
up in time, thus they spend a little more time oiling before they are spat out,
not as cleany for the very high flashpoint ones, and that is the compromise.
And that I agree with, I would take the Castrol 2T or Motol 710,A higher flash point like the Motul 800t in normal wood cutting and a ratio tuned rich say 32to1 is difficult to combust completely. Takes a heavy load and higher temps such as milling to completely combust and form a good carbon crown with transfer
I had to run it at 42to1 on my ported 461 tuned to 14700 and a 28" buried to combust it and form carbon on the crownSo would Motul 800 be better run at 40:1 or 50:1?
In a ported saw of course.
And that is what I would think too, but am only learning, I would not useI had to run it at 42to1 on my ported 461 tuned to 14700 and a 28" buried to combust it and form carbon on the crown
That is what I would conclude, but to take all that oil has to give,Motul 800 must lube well then if it doesn't combust and form carbon on the piston crown.
I think me and you is on the same page, and after a day looking into oil,IMO each oil has its characteristics that react to combustion, but each saw will react differently with load, tune, and temp. To different oils. From the testing Ive done each saw has to be setup with an oil to the paticular job it will do. Guess what Im tryin to say is what works for one may not for another. This is Red Armor in my 346xp at 40to1 and tuned to 14800 with a 16" bar for limbing and smallwood. In my mind thats a good balance between being safe on the rich side alil and combusting enough for performanceView attachment 96098
And I may not be posting at all only for someone on another forumIve used the oils I listed a few posts back in small handhelds to ported saws noodling all mixed at 40to1 with 97efree to 93 efree. All have performed really well
Ive used a good bit of Amsoil Saber and it produced the most Ash depoist of any oil Ive usedI use Red Armor because of what you posted Keith. Lol
It does perform well.
I also like the VP oil too.
I will admit, I wasn't impressed with the Amsoil Saber.
