mdavlee
Hillbilly grinder
7:53 AM
TN
yeah but no one has actually tested it. It's like saying xyz port timing #s should work the best. key word should. That don't always work out like ya think.
I know my Echo 225 wouldn't run right on H1R, Super techniplate, motul 800, and R50. Mobil, original techniplate, Hp2, and saber it ran ok. Saber was best besides Mobil and the VP 50:1 fuel
KenJax Tree
¯\_(ツ)_/¯
7:53 AM
Over there
I would love to hear your feed back and thoughts after you run it a while. The smell kinda bothers me in a very close still area.
Since i went into mangement at the beginning of the year i don't burn much fuel anymore. I'll burn most of my fuel doing yard work at home now.
mdavlee
Hillbilly grinder
7:53 AM
TN
661 doesn't run right at heavy ratios of those either. H1R runs slow. Super Tech makes a mess. 800s slower at 32:1. R50 doesn't run right at 32:1 (saw bogs down after multi cuts in a row). All of them are high temp and thick oils.
mobil one, orig tech, hp2, and saber all run fine at 32:1. not sure orig tech is exactly clean at 32:1. but it runs decent.
So far I've not heard any evidence or feedback to say a particular oil that runs good in the 661 won't run good in a weedeater. Providing the correct ratio is used of whatever oil.
I DO think there is evidence that a different ratios of the SAME oil should be used in different ope tools or sized engines or ported engines.
Those oils worn fine when milling in saws that aren't autotune/mtronic. The load cutting get firewood isn't enough to burn them unless you're in 60-70" wood and a cut takes a tank of fuel.
mdavlee
Hillbilly grinder
7:53 AM
TN
bike oil will burn in a lawn boy if the grass is half feet tall.
Plenty of load then. I've milled with all the stuff that burns dirty or just oozes out when cutting firewood. They all work but I've see the cylinder Temps hot enough to melt temp sticks at 550°
jake wells
no longer here
6:53 AM
ky
ive had my lawn boys so hot it would boil the gas the in carburetor and get vapor locked.
Keith Gandy
Maxima K2 40:1 87 Pump Gas
6:53 AM
Provencal, Louisiana
Well did you try those oils at 50:1 in your echo225...how did they run? and if you did run them at 50:1 why didn't you just state that from the beginning...would have saved this back n forth.
If you didn't, then I rest my case. There is no evidence put forth so far.
Furthermore I don't see why now after 20,000 posts on these oil threads (OPE and AS) that now all of a sudden we need the "best" oil to work in all OPE. Who is going to test that? Not me!!!
Aww heck!! Cmon now!!:D
mdavlee
Hillbilly grinder
7:53 AM
TN
If you didn't, then I rest my case. There is no evidence.
Furthermore I don't see now after 20,000 posts on these oil threads (OPE and AS) that now we need the "best" oil to work in all OPE. Who is going to test that? Not me!!!
Nope. Several worked fine at 32-25:1. I haven't mixed less than 40:1 that I remember since I got away from ultra in 2009.
