skidooguy
Genuine smartass
3:37 PM
Wyoming
I put many miles on a trail boss 250 @jake wells it wasn't very reliable but it ran great for short periods of time. Is yours oil injected or did you make it premix only.
jake wells
no longer here
4:37 PM
ky
it was oil injected and reliable other than flat tires and having to replace a worn out drive chain.
bwalker
5:37 PM
Montana
Says it's reformulated ope oil.
Nothing about boats. It's premix only I believe
I did a little digging and royal purple is indeed a ashless tcw3 type marine oil. I would not use it in saws.
stihl sawing
4:37 PM
Arkysaw
Just tore a engine hoist down to clean all the hard grease out and refresh it with new, It was full of that stinkin gear oil smelling grease. Done washed my hands three times with hand cleaner and others and still smell it.lol
bwalker
5:37 PM
Montana
The air strykers in my experience need a lot different jetting than the normal carbs. Especially on the needle and mains. Who was LRD?
This has been my expiereance as well. They have a much stronger signal than a standard PWK.
stihl saws
You can always justify another saw.
5:37 PM
Virginia
I had a opened bottle of gear oil leak out a little in my car trunk. Months later it still stinks like it.
Redbull661
661 hoarder (BlueBallz)
4:37 PM
MN
Belray si-7 run at 32:1 with 91 e free. approx 2.5 gallons of mix
junkman
Crush it
2:37 PM
pacific northwest
leaves some ash deposits like h1r does ,good colors on the plug and muffler though as for burn from what i can see ,looks to be blue ,so it must be good oil ,lol
junkman
Crush it
2:37 PM
pacific northwest
I had a std 39 pwk once ,on the 250r it never ran near as good and easy to ride as the pwk carb
I looked on my shop wall for needle specs ,i painted over them when i repainted my paint booth room
DEJ or DDJ rings a bell though the taper was kind of lean so i had to run in the 4th clip from the top .
CR500
5:37 PM
Western NY
How does the stuff compare to H1R?
Ben any comments on SI7?
jake wells
no longer here
4:37 PM
ky
the si7 smells worse than h1r but si7 has a pretty blue color when mixed.
Time's Standing Stihl
Below me...
5:37 PM
Central Iowa
Holy chit! Can't believe this thread is going still. Big thanks to all those that have been testing.
I haven't looked at this thread in 6 months. Have we come up with a top 5 yet?
Sent from my SM-G900R4 using Tapatalk
jake wells
no longer here
4:37 PM
ky
we have written a novel about oil just for you ya better start reading.
