CoreyB
- 12:31 PM
- Jan 26, 2016
- South east iowa
I think the consensus is most oil is just fine. The average Joe on a stock saw will never find the limitations of the oil. Except stihl, that stinky gunkey crap. Oh and over priced. I would run polan pro synthetic over stihl. LolSo, without reading hundreds of pages of info, I have gathered that it seems most of you guys do not like the Stihl Ultra oil. It would be neat if someone added a poll to this with the different oils and let's see which oil gets the most love. It may sway a few other people to decide it is worth trying that particular oil. I have been happy with what I am using, but I have a few Vintage saws that I will likely not be able to get a P&C for, so in my paranoia, I am looking to try something different...
Man yall r makin a mistake by knowing what protects best in saws and using visual inspections along with practical grease monkey knowledge in deciding to use that low life low rpm Klotz??!! Yall should trust that lab data and spec sheets on oil. 800t has to be the best oil for yall to race? Myself I will call 800 out to being full of zinc and a overated decarbonizerThen you got a piss poor operator here with DULL chain and way more r's in the small cant racing practice.
Awesome!!Then you got a piss poor operator here with DULL chain and way more r's in the small cant racing practice.
rotten pine cant don't countSame piped saw ran on muffler for kicks. Ported for pipe, not muffler.
Ive seen some horrible carboned saws, blowers, and trimmers ran on Stihl Ultra. Had to use porting tool to grind out exhaust port. A few were so bad that the exhaust port was more than 50% smaller than it started
I used to run Husqvarna synthetic until I worked on an 044 for a guy that was clean as a pin. He was using ultra, so I switched after seeing how nice the oil blanket looked on his piston. From what I am reading, I shouldn't have made the switch...
Any 2T oil will work at the correct ratio. I'll ask the same question I asked on AS. Has anyone ever experienced an engine malfunction using ANY brand of 2-cycle oil mixed at 32:1? The answer on AS was no.13k in the cut?
If klotz original is good enough for the guys with $5k in a 3120 race saw its plenty good for these 6-8 hp ported saws.
Yours don't have the correct sticker on it.....TN*B-S....!! In the cut?
Only problem I had was with h1r. Couldn't tune rich enough. It almost seized an 066.Any 2T oil will work at the correct ratio. I'll ask the same question I asked on AS. Has anyone ever experienced an engine malfunction using ANY brand of 2-cycle oil mixed at 32:1? The answer on AS was no.
It still 4-strokes above 15KAs fat as his saw is I doubt it turns 13000 no load.
