What? No bandsaw milling threads?
12:28 PM
Don't You guys cut and weld them?
Here bandsaws get welded as long and as often as there is meat on them to make it viable.
geslayton
5:28 AM
I don’t, I’m using 1-1/4” bands. Once a couple teeth get broken off or they break, I trash them.
Sawdust Man
Manufacturer of Sawdust
5:28 AM
MO USA
Definitely not worth welding em, they are usually work hardened by the time they snap and just brake again very soon.
We tried it many moons ago.....
EFSM
5:28 AM
Extreme southern IL
At a whisker over 20 apiece, I don’t see how it would be worth it. Interestingly, I have only had 1 1/2” blades break, never 1 1/4. Some of our blades have probably been sharpened at least 6 times.
lehman live edge slab
Live Action
5:28 AM
Mn
Some of the blade breaking has to do with the size of the drive wheels for the blade the bigger the better it seems
EFSM
5:28 AM
Extreme southern IL
It also depends on how dull you run the blades. We have a neighbor that sharpens and sets them for 7 or 8 dollars. For that it’s not worth running a dull blade.
Sawdust Man
5:28 AM
MO USA
More truth, and probably the biggest reason blades brake too early.
geslayton
5:28 AM
Are you offering sharpening services to anyone? There’s a guy on Facebook looking for someone in Southern MO to sharpen blades. I can give him your number if your looking for some to sharpen.
Sawdust Man
5:28 AM
MO USA
I was.....but I'm not anymore.
Busy making better money.
Fleethirte
6:28 AM
Virginia
What rpm is the mill engine suppose to run?
I feel like i have mine revving to high.
I think its the kohler 14 Hp
EFSM
5:28 AM
Extreme southern IL
Does anyone have experience milling octagon shaped beams/pillars? My dad and brother and I were working at milling some pine today for a house interior and we tried an octagon shaped pillar for the first time.
Live Action
5:28 AM
Mn
No experience doing one but I’d imagine you would need a fixture to place on the bed to hold it accurately for at least the first cut going from square to octagon. Kinda like a v-block to set one corner of the square post in.
EFSM
5:28 AM
Extreme southern IL
That’s what I was envisioning too. However, simply setting the cant on its corner and using a speed square to find 45* seemed to work well enough. The project requires only 2 posts.
