What did I do wong
stihl_head1982
Here long time
5:19 AM
USA
That's what I was thinkin. I guess oem for me now
Some things you just cant skimp on (I'm learning that the hard way). Buy new OEM clutch springs. You will probably be ok.
Was it an OEM clutch with Aftermarket springs, or just an aftermarket clutch. Just curious.
Mark71gtx
5:19 AM
Fuquay Varina, NC
The cost of OEM springs is not the issue. It is the ability to go to the Stihl dealer, have them order them for you (they certainly will not have them in stock), wait until they call you to let you know they are in, and go pick them up. These things can be a real problem for people that have to work for a living.
leadfarmer
Hot Rod !!!
5:19 AM
S Central PA
Springs on oem clutch
  • Like
Reactions: DSS
stihl_head1982
Here long time
5:19 AM
USA
Definitive Dave may be your huckleberry. He does sell OEM parts.
Although I know well your quandry. Finding a dealer who orders promptly and prices fairly can be a challenge in some areas. I finally did, and am very thankful!
67L36Driver
4:19 AM
The Chinese are not good on controlling the quality of the material (steel)they use to make parts.
Quite often subbing whatever is available instead of using AISI 1090 (spring wire) use maybe a much lower carbon such as 1074.
I've also noticed nicks in the surface (stress risers) from the bending dies of their spring winding machines.
Piston pin retainers are another.
TJ the Chainsaw Mechanic
Old Homelites rule!
2:19 AM
Understood, we tend to keep high speed parts like that well stocked. Though replacing clutch springs over here is fairly rare, I am not surprised when a logger brings in a saw with them broken or weak. Hence why we stock at least 6.
I guess what I meant by cost is that the OEM ones at least around Here are pretty cheap. Normally aftermarket is cheaper.
Mark71gtx
5:19 AM
Fuquay Varina, NC
The cost is a non-issue. Availability is the issue. The dealer's out here don't stock springs. If fact, I have yet to go into a Stihl dealer and walk out with the parts I was looking for.
Old Homelites rule!
2:19 AM
Yep, they don't care. They are more interested in selling those zero turn mowers...
Whatever brings more money. It's rather stupid what some of these business owners will do for a profit. I was lucky enough to find an honest business to work for. We actually get a nasty talking to if we don't restock parts. haha
67L36Driver
4:19 AM
Even if you get oem springs, the clutch still may engage as the holes the springs hook in become oblong
The cost of springs plus shoes at my local Stihl dealer is considerably less than a complete clutch. The spider is the most expensive part across the counter.
jmssaws
Banneded
4:19 AM
I've used a lot of am 1122 clutches and the springs do break but I change them now before it's ran.
The clutch ain't bad for the money.
