What are the top 5 things you check when a saw doesn't start?
Mattyo
Youtube speciawist
2:27 AM
Farmington, CT
compression fuel spark.
some brake cleaner down the throat of the air horn is an easy test to see if you have compression and spark
check for flooding by removing the spark plug, look inside cylinder to see if there is scoring
remove fuel line and check for fuel coming out...
bikemike
1:27 AM
Cottage grove mn
I check for a starter rope and handle, fuel that's not watered down, if your feeling lucky check the on off switch, if that doesn't work check chain tension, still no start then check spark screen and make sure it has spark
maulhead
12:27 AM
Home
1)is the @Mastermind sticker still on it, or did it get peeled or rubbed off
2)is it the NE or OE sticker
3)why is the phone number on his sticker no longer in service
4)is the switch in the off position
5)did I install the blade upside down or backwards
Member
1:27 AM
Can do it in four.
Intake - engine needs both air and fuel/oil mix to run check filters air and fuel.
Compression - needs at least 100 PSI minimum to be able to run at all. If it feels weak, check it.
Power - A good healthy spark is required to light the fuel air mixture under compression. This is a good place to start by pulling the spark plug and checking for fuel and spark at the same time.
Exhaust - While not as common a plugged/blocked exhaust will not allow an engine to run.
It always comes down to these four things, always. Intake, Compression, Power and Exhaust. If you check for them you can diagnose any engine, 2 or 4 stroke.
Onan18
OPE Sponsor
2:27 AM
Georgia
Stale fuel is probably number one in my shop
Ignition switch off is second
Bad fuel lines, plugged up fuel filter is number three
Air filter plugged solid is fourth
Fifth is start looking for an actual mechanical issue
Philbert
Chainsaw Enthusiast
1:27 AM
East Dakota
I think that part of the differences in responses depend on whether, it is:
- a saw that has been running, but just won't start. Or;
- a saw that maybe has been sitting for some time, is unknown, is being offered for sale, or brought in for service, etc.
Philbert
