- 4:02 PM
- Dec 29, 2015
- Strong Island NY
It's Randy's recipe.
If you do I think it needs to be opposite the notch. And if it doesn't work you can solder it up.Ya know, I'm wondering if the butterfly needs to be drilled?
I know from my hot rodding days, engines that pull more air need the butterflies drilled for idle. Otherwise, they need the butterfly open to idle correctly too much, and it exposes the idle slot and floods the motor.
@Terry Syd ?
If you enlarge the notch it is still pulling the air over the idle jet pulling fuel. If you drill it opposite it adds air without fuel.Opposite the notch or enlarge the notch?
I don't even know what carb that is.Do you have a C3A-S Zama laying around?
@Terry SydDrilling the throttle plate or putting a notch opposite the idle notch will lean out the idle, but so will more seat pressure on the metering valve. A couple of washers under the spring will make it more difficult to lift the valve and will lean out the idle. It works similar to dropping the float bowl level in a float bowl carb, it takes more 'suction' to pull the fuel up from the bowl.
You may have a stronger metering spring sitting around, why not give it a try before drilling the throttle plate.
I don't have another spring. I have the lever set around .015 lower than it should be. Should I try to take it further?
It's loading up with fuel when it idles. If I lean out the L screw, the saw stumbles to accelerate when the problem is not there-between cuts when it hasn't idled for long.
Agreed.Kinda weird that it takes so long to come down from idle. Sure does sound like it's getting air from somewhere.
what is your intake at now? I'm sure you said it but I can't rememberThis is frustrating the hell out of me.
I'm not even sure if my others haven't done this. I just may be more attentive now.
Again, under normal use there's no issue. Let it idle for, let's say, 30 seconds and it wants to die when you pull the trigger. Let it idle normally between cuts, no issues.
Is it possible that it's just pulling so much vacuum it's pulling fuel out of the orifices?
This saw has a short intake duration and a flat wide port, unlike the others I've done.
I'm almost at the point of pulling the jug again and giving it 6* more intake duration.
Im at 74 I believe.what is your intake at now? I'm sure you said it but I can't remember
I'll try that Joey.Pull the air filter, saw idling, take a light and look into the carb, what is it doing?
If it is slow to come down to idle, you need to richen the low side. Try that and report back.
