- 9:07 AM
- Dec 3, 2015
- Banner Springs Tennessee
Looking damn good Al. Your attention to detail is amazing my friend.
@drf255
Does your compression tester have a Schrader valve in the bottom of the hose? I guess I don't see length of hose as a factor, although you'd have to pull a few more times to fill the hose with air.
If you make the area between the Schrader valve and the piston larger, comp will go down.If you made the combustion chamber bigger, and pulled a few more times, would you gain, lose, or keep compression the same ?
Some testers only have 1 valve, and it's in the top by the gauge, is why I asked. And they don't work for doing what we're doing
I guess I see what you're saying now tho. If there's a valve in the bottom of the hose, like right where the electrode on a spark plug would be, if you used a longer hose you'd just have to pull more to fill the hose with compressed air.If you made the combustion chamber bigger, and pulled a few more times, would you gain, lose, or keep compression the same ?
It's not an extension of the combustion chamber tho if the valve in the bottom works. You're trapping the air between the gauge and the head. You could have a 10' length of 4" pipe for a hose. And if you pulled enough times you'd eventually fill the pipe to the same capacity which was produced inside the headI understand the schraeder valve needing to be in the screw in adapter.
I question the area inside the hose.
At the end of the day, I see it as an extension of the combustion chamber, with or without a schraeder in the adapter, it is still volume to be accounted for
Thanks Randy. Build threads are my favorite. A way to learn and brainstorm. There's a lot of interest in the little 024/026 and I'm liking that a lot.Looking damn good Al. Your attention to detail is amazing my friend.
@drf255
Nice build thread, btw
I'm seeing it both ways and I'm a bit confused as well.If you made the combustion chamber bigger, and pulled a few more times, would you gain, lose, or keep compression the same ?
Damn! I've only got an inch so far. Supposed to get 6-10... 30" would be quite the money maker for me!!!Saw's together. 70mph winds and 18" of the forecasted 30" of snow is cramping my style. Not gonna have the time to start this guy till tomorrow, and even then, not sure where I'm gonna find something to cut.
The covers didn't clean up well. I will post a video of it sprinting when possible.
View attachment 5940View attachment 5941View attachment 5942View attachment 5943
Sure it's not residual oil?Thanks.
The good news is I got it running and no explosion.
Bad new is 30" of snow, some fuel delivery issues, and a slight rub on the piston skirt (but not the crown or rings).
There was some case corrosion, and I just can't let the rub go, so its coming back apart for a check.
I could be wrong here, because the rub is so slight, but I just cant not do it.
Looks great , I have found some really nice used 024 plastics on eBay for little $$$, you just have to spend some looking through them. Just a suggestionSaw's together. 70mph winds and 18" of the forecasted 30" of snow is cramping my style. Not gonna have the time to start this guy till tomorrow, and even then, not sure where I'm gonna find something to cut.
Not oil. Polished the machine marks off in a line. Very slight though.Sure it's not residual oil?
As long as the valves at the tip (and its working correctly) the length of the hose has no bearing on cylinder volume. The pressure in the hose will be less than the incoming charge from the piston until it fills. Course then your guage wont read any higher.Thanks Randy. Build threads are my favorite. A way to learn and brainstorm. There's a lot of interest in the little 024/026 and I'm liking that a lot.
On one hand, there's no way to get pressure into the hose unless the valve is opened by a pressure differential.
On the other hand, the moment that valve opens, the total volume of the vessel is increased to the chamber plus the hose.
I'm still not clear here.
This is where I wonder about something.As long as the valves at the tip (and its working correctly) the length of the hose has no bearing on cylinder volume. The pressure in the hose will be less than the incoming charge from the piston until it fills. Course then your guage wont read any higher.
