brandonstclair20
- 6:02 PM
- Nov 21, 2016
- Starkville
I got a heat gun today. I heated the flywheel side of a huztl ms440 case. I took a socket and tapped out the bearing. I heated the case and went to put the bearing in and it went in half way and I guess the bearing got hot and expanded too. So now i guess, I’ll just have to use a bolt, nut and washers to pull it in. On the clutch side, i assume I heat around the bearing like I did on the flywheel side? Anyone have any more tips on this method? Thanks
