Ultimate "Firewood" Saw
FordTruckMan
6:31 AM
Ohio
In an effort to keep this post from being three pages long, here is the bare bones. I have two saws, neither do quite what I want, and I am considering buying a 3rd saw.
I have two totally stock Stihls, an MS290 with a 20" bar, and an MS661-CM with a 36" bar. I use these saws solely for firewood to heat my house, which can include felling smallish trees (18-24") and bucking as big as 50".
The 290 is dead reliable but underpowered. The 661 is not so reliable (won't hot start sometimes) and underpowered for the size bar I am running. I am open to basically ANY solution to get a saw(s) that perform "well" in all hardwoods up to 50" diameter.
One consideration I had was putting a smaller bar on the 661 and using it for my primary bucking saw, and getting a larger, or highly modified saw to run the 36" bar. Is that nuts?
Then I saw there is a "new" 462 that weighs exactly the same as my 290...but has nearly double the power. That sounds too good to be true.
Things that are important to me, in order, are:
Reliability!
Torque
Antivibe stuff...I have nerve problems.
I don't have any preconceived notions about much of anything, I am too green. I have no brand loyalty, but do have access to a Stihl dealer that gives very decent pricing. I have been doing the firewood thing since 2011, but thats all the experience I have. Please feel free to enlighten me if I do not seem to grasp something, I am not very well versed in this stuff. I am also happy to share more information, I just wanted to keep this short for you guys.
Thanks in advance,
FTM
cus_deluxe
terms of service violator
6:31 AM
Michigan
a stock 661 should be able to pull a 36” bar well with a good chain. depending on your budget, there are a lot of options. if u wanna stick with stihl, id try to find a nice 361 from a member on here. if money is no object the 462 is certainly a sweet saw for sure, if you wanna spend $1100 on a firewood saw...
FordTruckMan
6:31 AM
Ohio
Maybe I am little too harsh on the 661; it will pull the 36" bar, but it doesn't do it well. I would like to be able to lean on it a bit, whereas right now I have to feather it. The saw has absolutely no bottom end torque at all. I try to keep my chains sharp to avoid overheating the saw, and generally make my life easier while cutting. I am using full chisel chain FWIW.
As for spending $1100 on a firewood saw, I know it's crazy, but I spent more than that on the 661 back in 2015. My sole heating source is firewood, and every month I use firewood instead of my electric strip heaters, it saves me $400-600. So any saw I buy will pay for itself in no time.
deye223
AIR FUEL SPARK VROOOOOM
8:31 PM
Australia
I am sorry I don't understand what you are saying here??
You asked about the best wood saw and I just read a bit about the ms400 and it's not real good so I don't think you would want one ......
Bigmac
3:31 AM
Oregon
The 462 is super light and am sure is going to be a great saw for a long time, going more old school will keep things simple, a 361, 440 or 372 are great options in the mid size range. The 661 is a fine saw, but can have some issues, if you make long cut and shut it off or run it out of fuel in a cut they can be hard to start, I try to always let a 661 idle for 30 seconds before shutting it down. A ported 395 is a great big saw option, it’s simple and effective, I don’t have one. Porting makes a big difference on the 661 too! That’s a great option a 261 462 and 661 should cover most of your needs
Bigmac
3:31 AM
Oregon
Porting wakes up the 661, I did a base gasket delete widened the ports and a single big port on the muffler and it now has some bottom end, I know what you mean, I was disappointed in the 661 stock!
Bigmac
3:31 AM
Oregon
this isn’t ported, if it had about 15-20 pounds more compression I think it would have a lot more torque, but as is it now handles the 36” bar well, and this is an 8pin sprocket, are you running a 7 on yours with the 36” this saw is fun with a 28” bar
FordTruckMan
6:31 AM
Ohio
I have not changed the sprocket from stock, so if 7 is what came on it, that what it has lol.
the 462 will serve you well replacing a 290 , the 661 should pull the 36 in bar fine sounds like you need a mastermind port job on the 661 I bet it will haul the mail then
I did actually contact Randy before I found this forum, but he no longer works on used saws. I had him price me a new 661 ported though, which is part of what I am having trouble making a decision. If he was willing to work on my existing 661, I would put it on the mail at the end of this season, regardless of any other saw I may or may not purchase.
Bigmac
3:31 AM
Oregon
Mine had an 8 on it, it’s worth checking, a 7 would help with torque on the 36
tree money build a mean 661!!
460 magnum
5:31 AM
Very southern Illinois
I'm sure there are plenty of other people on here that would port your saw.
MarcS
5:31 AM
West Central WI
I’d say clean the 290 up decent and sell it for $350 since people think they are made of gold...put that money toward a new saw. 462 has my interest but I still haven’t got one to say first hand if it’s the holy grail or not.
Get a nice 50cc to pair with the 462 and also get the 661 ported.
I like that you are thinking big trees for firewood Some of my favorite days in the woods have been dealing with the monsters.
Disciple of Monkey's
5:31 AM
The 462 could go down as one of the bestest firewood saw's so far, right out of the box.
Not that there aren't a lot of other excellent choices out there as well, most have been mentioned already.
trooney
Admitted Woodaholic
6:31 AM
The land of pleasant living
Spend $350 on getting a port job on your 661 and pocket the savings. I have a 28" and a 36" bar on my ported 661, pulls it just fine. Run .404 on it. Like was said before, there are plenty of people here who can port a saw. All depends how much you want to pay for shipping..
