- 2:39 AM
- Dec 4, 2015
- In a meeting
OK so clearly I need to look harder for someone to port my 661.
THIS !!!
THIS !!!
Same level as Randy ??? ............. count me outPlease feel free to recommend someone! I only found Randy from a google search and another forum...If anyone is reading this that ports saws and would consider themselves on the same level as MasterMind, please reach out to me.
Check the PM I sent you...Sorry, is that something that's not likely to happen? I don't mean to offend anyone, I simply don't know any better. I am making the assumption that Randy is really good based on various posts I have read about his reputation, and the fact that he has a website and a 3 month back log.
I would like to have someone who is just as capable, is that a more fair way to put it? They don't need a website and a 3 month back log lol. I just want someone who can provide proof that they know what they are doing, and isn't going to screw me over.
Ima send you a suggestion tooSorry, is that something that's not likely to happen? I don't mean to offend anyone, I simply don't know any better. I am making the assumption that Randy is really good based on various posts I have read about his reputation, and the fact that he has a website and a 3 month back log.
Vid?a ported Echo 490 is excellent with a 20" bar.
You forgot how bad they smell. ..Ported chainsaws are overly loud, and they frighten me.
The 661 can be ported specifically for more low end torque. An oil pump modification should help it pull a 36" well. I don't like running bigger than a 28" on a 661 for low oil output reasons. The 661 is a extra short stroke saw too, so a 395 might be the way to go.
Echos are built for torque, but I have no idea how well a ported cs800 pulls a 36". They are long lasting and cheap to buy and maintain.
If you know how to use peaky saws without low end torque, then they pose little problem. Just keep the chain sharp and the depth gauges filed enough to where the saw self feeds well with the whole bar buried in wood without pulling it out of that peak power band. My Jonsered 2188 (husqvarna 390) was like that, I didn't lean on it, just helped it along as it flew through wood at 9500rpm. With a 7t and Stihl square skip chain and a super oil pump, it had no problem burying a 42" with only a muffler mod.
I think a Husqvarna 572 would be a great all around saw to replace the 290 and 661 for non 36" bar cutting, but for something extra light weight yet capable, a ported Echo 490 is excellent with a 20" bar.
Nobody likes this hack or recommends him in PMs.I'll have time in early January to port your 661 if you'd like.
I forget there's some stupid thing like that.All you have to do is punch the pin in for a 36" bar and it works just fine. No mod required.
It certainly would be more cost effective than buying a new saw.I'll have time in early January to port your 661 if you'd like.
There are some great porters here BUT don’t sell yourself short. That 661 you built me is the single most impressive saw I have ever runSame level as Randy ??? ............. count me out
