New saw, cant decide.
fishbones
Active OPE Member
1:19 AM
Michigan
See if you can get a light bar. You won’t regret it.
I looked into it, it was 50 bucks more and on a 25" bar they said it was like 2oz lighter so I opted to stay with stock bar but not the safety chains, got full chisels instead.
Loony661
462’s 4-LIFE
12:19 AM
Winona County, MN
A light bar in 25” is about 2 lbs lighter than the standard. My 36” Light bar was 3 1/2 lbs lighter…
fishbones
Active OPE Member
1:19 AM
Michigan
Wow, thank you, I will look into that, 2lb is a lot.
Whats your thoughts on the dyno's that show the 462 light on torque? Any easy ways to get more torque besides porting?
Sloughfoot
10:19 PM
Norcal
Balanced saw is a wonderful thing. My 044 is moderately nose heavy with a 24" regular weight bar and near perfect with a 24" Tsumara Light so figures that a lighter 462 should be even more nose heavy. 462 with a 24" Stihl ES Light is probably perfect, the ES being a bit lighter than a Tsumara light.
Well worth the extra $50 to me.
fishbones
Active OPE Member
1:19 AM
Michigan
For some reason I am still struggling with the 462 Mtronic vs Non Mtronic.
The saw shop guy seemed pretty adamant about not getting an Mtronic version but my research shows a lot of guys like them and they are not having issues. Any thoughts appreciated.
Khntr85
1:19 AM
Indiana
I went back and forth with this on the 261c….came across a deal on a brand new 261 mtronic and so far it’s great….time will tell I won’t baby it…
Sloughfoot
10:19 PM
Norcal
I enjoy tuning my saws to varying conditions and am ok at it. That being said mtronic would probably do it better, especially since I only tune the high jet.
pwheel
Finis Origine Pendet
1:19 AM
MA
My local Stihl tech is old school and doesn't care for m-tronic or fuel-injected OPE. Says with a manual carb saw, you can fix just about everything with a screw driver. So in my case, I'm happy to run what the tech is happy to service and that means a manual carb. And a tachometer. And a willingness to be fussy.
As far as torque, the ms462 may not be as forgiving to run as my go-to ms461, but it will probably get the job done faster with higher chain speed.
fishbones
Active OPE Member
1:19 AM
Michigan
Thank You, appreciate the info. I just ordered a proline solo tach, I like old school so sticking with what my local tech with 40 years experience suggests, manual carb.
Catfishclark89
12:19 AM
Glasgow, KY, USA
I’ll tell ya. I use saws in a production felling environment. We’ve used the 462c. I really like how it self adjusts. It’s a high strung saw. I like manual carb saws as well. No trouble for me to tune one. We put many board feet on a 462c before something happened with the communication of the mtronic system, but a trip to the dealer fixed it pretty easy. IMO if the saw is being used as a farm/landowner/cut my own firewood saw; stick with the m-tronic model. If the saw is being used in a production/tree service/production firewood then get either the m-tronic or standard carb. Just my two cents.
Catfishclark89
12:19 AM
Glasgow, KY, USA
Welp… just read this after my previous post lol! Glad you bought a tach to use. Always good to know for sure 👍🏻
Loony661
462’s 4-LIFE
12:19 AM
Winona County, MN
If being a little louder doesn’t bother you, the Bark Box by West Coast Saw really does add torque to the 462. They say 10% gain, proven by dyno results. I have them on both my 462’s. It’s a noticeably felt difference.. I always wear ear plugs when using my saws.
fishbones
Active OPE Member
1:19 AM
Michigan
Cool, great info. I was looking at those and a west coast filter kit but some info I found says muffler mods dont do much to the 462 but now we know they do, thank you.
Loony661
462’s 4-LIFE
12:19 AM
Winona County, MN
The stock air filter setup is great as well. It’s way ahead of it’s predecessors in terms of staying clean. I can cut for days logging without “banging it out” for a quick clean.
Squish9
3:19 PM
Australia
Which light weight bar did you get?
I have a 25" Stihl light 06 bar and a 25" GB hard nose here and the weight difference is 310 grams. Thats a bit over half a lb and nothing about that GB bar is light.
Loony661
462’s 4-LIFE
12:19 AM
Winona County, MN
Tsumura Premium Light.
Motorka
7:19 AM
EU
Five years ago i choose 565 over 572 it was cheaper 250€ ?
