Trivia/riddle: when is a plastic clamshell actually better?
Woodslasher
Teh debil
8:52 PM
Commiefornia
For reals I'd say weight savings, cheaper to produce, more compact design, and less potential failure points as well as what Kevin said.
NPKenny
9:52 PM
Lehi, AZ
Absolutely for palm trees. Only good use use for larger plastic clam shells like MS390 or MS391. 70cc would be better.
Dropping weight on a 50cc platform. Example is the 346 top end on a 350 chassis. Not really much advantage here, but it is a pleasure to run.
Wood Doctor
Edwin
10:52 PM
Omaha, Nebraska
Suppose you have a Stihl 290 that you hate. The mechanic who installed the last ignition module (now dead) stripped the threads. Now you can't even remove it to replace it. You now have a good excuse to throw the saw into the boneyard for parts.
11:52 PM
To start a bonfire
10:52 PM
When it takes a fall and or smacked by a tree and has everything broken except the crankcase. The honeycomb design makes them extremely tough.
When repairs are necessary, there's no case to split, bearing/seal replacement is a snap compared to a mag case saw.
