Trees you've cut
Allanb8d
3:57 PM
Texas
Thanks I think I have roughly 2-3 mil bd ft total on the saw. Idk for sure I never kept track of stuff like that. I figure 2-3 years on a logging saw is 10 years for a firewooder. I swapped the shortblock about 150 hours ago when it got that tsumura bar on it (it’s a tsumura you just can’t see any of the paint anymore). Pto bearing wore out. Still original topend, piston, carb, ect.
Did you ever run the 572 against a 462 felling? How's the vibration on it?
Not trying to start a saw fight but I have felled with the 462 before in hardwood and the vibration is a bit much. There are days where I would only do 2-3 trees, granted 28+ inches, and my knuckles and hands would be real numb at the end of the day.
BonScott46
10:57 PM
Sweden
If you are experiencing that kind of numbness after a few trees i would say you are very sensitive to vibrations.
Allanb8d
3:57 PM
Texas
Could be. Wore gloves and stuff. First couple times felling with it was 10 plus trees day. Got numb. Then the one day it was only a couple trees and that's what got my attention.
Don't have the same problem when I fell with a 7900.
4:57 PM
Yes the 462c does vibe a tad more than the 572xp. But I think it’s more due to the smaller piston/longer stroke motor setup of the 572. It’s not a huge difference though. I’m thinking it might have been your chain was too aggressive?
Allanb8d
3:57 PM
Texas
It was a half skip full chisel on a 28in bar. I really like it, super fast on live trees.
And yeah, semi chisel is pretty rough bore cutting. I used a 25in full comp semi chisel before that, super rough. Had to use a different saw with less aggressive chain to start the bore.
4:57 PM
I'll bet if I strapped a pound and a half lead bar to it that it would feel smoother!
They feel very smooth to me, but I do run full comp square file.
