- 3:20 PM
- May 30, 2016
- Ct
Yes they are from the 661. The 500i and 572 have softer springs. The 500i definitely needs the spring swapped for the stiffer one off the 661. It’s a little floppy stock. You can put stiffer ones on the 572 as well, but for the shorter bar lengths I run it’s sufficient. The only one I’ve broken on the 572 is the lower rear tank mount twice and it was my fault both times.Maybe 462s have stiffer springs?
