TreeMonkey Red Light 066 Build
markds2
7:20 PM
Nelson, New Zealand
Two thoughts. (1) For a guy that has never done a build thread -- you, sir are knocking it out of the park. (2) Maybe its OCD, but go ahead and spring for the new "break area covers". This saw deserves it. If the paint is as durable as it is nice -- it is a job well done.
That cover appears NLA.... all my dealer shows is the code ending with 1105 which is the same for the MS660
Johnmn
12:20 AM
Minnesota
@markds2 how long did you let the paint cure prior to heating. I painted some 034 super cases and when I stuck them in the toaster oven for heating to set the bearings, they discolored and I had to start over.
markds2
7:20 PM
Nelson, New Zealand
It was 4 to 5 days including having them sit outside in the sun most days, very important to let enamel to take its time drying. Treated right, it is very tough and has a nice gloss. It spent 4 hours in the oven at 80 degrees Celcius and seems to have come up nice and appears tough (although it will chip when knocked with something very hard)
Kiwioilboiler
346 Pic Examiner
7:20 PM
Marsden Pt, NZ
What sort of oven seems best Mark? :p
markds2
7:20 PM
Nelson, New Zealand
After the expected wrestle to get the handle to slide in between the front AV mounts the next thing to do is slip the impusle over the nipple on the crankcase. I find that a pair of long nose pliers through here is the best place of any
And we get the ignition wires and their grommet in place:
And the intake all in place
stihl_head1982
Here long time
1:20 AM
USA
1:20 AM
i use a 12 inch pair of hemostats that have a slight curve alot easier to see around
markds2
7:20 PM
Nelson, New Zealand
In place with the throttle and fuel line connected
The original carb adjustment screw grommet was very hard but in good condition, a slight heat with the heat gun softens it enough for it to be pushed in place.
And the new gasket in place with a smear of 515
