The Swap Meet Thread
JimBear
11:07 AM
IA
Anyone have a used flywheel & key for a Stihl MS270 ?
1133 400 1204A
Edit : found one
Sawcrazy
11:07 AM
New London, MO
Looking for p&c and intake setup for a 288!
PogoInTheWoods
12:07 PM
Ohio
If you can't find good used OEM, Meteor makes a pretty strong and decent quality 288 top end..., at least mine sure is. I'd stay away from the cheaper knockoffs.
Shane¹
12:07 PM
Kentucky
Would anyone be interested in trading a dolmar 123, 133, 143 regular handle for a full wrap handle? I have a couple full wraps but would just like a regular handle.
Jay Hansen
Foothills Vintage Saws
9:07 AM
Glide, Oregon
I'm pretty sure I have one, I'll check this afternoon.
Jay Hansen
9:07 AM
Glide, Oregon
How much? I realized the handles I have are not for a magnesium tank they may be for a plastic tank or maybe a 153 not sure so I would rather not trade and someone not be able to use it
I honestly don't care which saw your handle will fit, I'll eventually find a use for it.
Shane¹
12:07 PM
Kentucky
These are the handles. One is in rough shape I was going to keep that one the other one is really nice
Thumper88
12:07 PM
Harriman, TN
Looking for the little brass piece for an 064 oil line. Pulled the taper out of mine on accident.
PogoInTheWoods
12:07 PM
Ohio
I believe the 084 uses the same one as well
It does. Unless you're using it to push the oil line down into the channel, it really isn't even necessary. That said, I do understand wanting to do it "right" if you're re-doing an 064/084.
If replacing the oil line carnage from a failed 034/036 small diameter clutch needle cage, not so much. LOL
Thumper88
12:07 PM
Harriman, TN
I pulled my oil pump to mod it for more flow and like the gorilla I tend to be I pulled it out the wrong way. It it being seated tight in the hole isnt necessary for function than I wont fret it to much
PogoInTheWoods
12:07 PM
Ohio
If increased flow is the objective, it would seem that re-installing the thimble would sorta defeat the purpose anyway just by being there.
Shane¹
12:07 PM
Kentucky
No I did not. I may just keep the ones I have now. I found one on eBay for $10 so I have enough for all my saws now
