The Swap Meet Thread
Billy Currie
3:38 AM
Asheboro, NC
Pretty sure even the early Quickstops used a circular band unless it's a variation of the short-lived isolating clutch setup used on some of the other saws of the era. I've not seen that in any of my 028 IPL's or early version 028AV / AVQ service manual.
Here's what is typical...
I wish I took a picture of it, but this one doesn't have a place to put the band in the aft position. There is a screw hole there that holds the cover, but the webbing on the case is in the way for that type to go on.
Like this one:
https://store.chainsawr.com/product...complete-chainbrake-kit-with-isolating-clutch
AlfA01
9:38 AM
Evia, Greece
I'm in need of some parts for some builder saws. I got 372, 044/440, 046, 281/8, 64/79XX parts and some other stuff to trade. Also PayPal dollhairs. Shipping to Oregon 97062.
395XP
flywheel
front AV spring
case screws
recoil cover and starter bits
Either 394/5
coil
crank and flywheel set
exhaust nuts
case hardware (screws)
front lower AV with screws
carb box and bits x2
bar studs x2
choke lever x2
air duct flywheel to carb box
case screws and basically anything hardware related
281/288
Clutch drum for rim sprocket
Ignition parts
Intake block for 181SE
jacob j.
Only the weird
12:38 AM
Coastal Oregon
395XP
flywheel
front AV spring
case screws
Either 394/5
coil
exhaust nuts
bar studs x2
choke lever x2
281/288
Ignition parts
I can help with some of these parts - It'll take me a couple days to dig through and see what I got.
AlfA01
9:38 AM
Evia, Greece
I have some stuff here Dan. Gonna need a few days to get to it though.
Thanks DJ. I was gonna send you a PM, but I just haven't gotten around to it. Life's been a little on the hectic side lately. Lol.
K Mueller
11:38 PM
Alaska, USA
Looking for a nice 36” .063 .404 Stihl bar in 3002 mount.
I have some handle bars I can trade or a 28” Stihl light bar in 3/8 .050
bottom are 1128 heated handle bars and top are 064/066 handles.
Bodell0
1:38 AM
Whitewood, SD
Alright guys, Ive been working on these 3 150s that were given to me. Common issue with the 150s, people drop them and creates an air leak around the crankcase, then burns out the top end. Got 3 new oem top ends but for the life of me, cant figure out how to spilt the small ms150s crank cases to re- dirko them. Ive tried every tool stihl makes and Im just stumped.
PogoInTheWoods
3:38 AM
Ohio
Actually, you should almost be able to pull the case apart by hand -- once you get the screws out and the circlip removed on the clutch side. Hafta know it's there, first. May be what's giving you grief.
Bodell0
1:38 AM
Whitewood, SD
I used the same puller but when I used it, like illustrated, puller pulled the screws out of the casing. I did have everything off that was necessary. Just was giving me grief.
