edju1958
- 11:22 AM
- May 23, 2018
- Western N.Y.
Thjis post will be a bit lengthy,but here goes.I bought a new sprocket drum for the 3400 about 15 months ago since the old sprocket was chewed up pretty good.I went to put the sprocket on the saw today,it fit just fine,but once the clutch was tightened up it'd bind something terrible..It was an old Sabre sprocket sold by Stens that had the replacement of an Oregon 32790X.Apparently it was packaged improperly.I put the old sprocket on from the other 3400 & all was good.I then fired up the 3400 & had oil puking out all over the pl;ace.Apparently the automatic oiler started working,but I'll need to cut a channel for the oil to flow to the oil slot with my Dremel tool on the bar pad.Things are looking up on the original 3400.
As for the newest 3400 I got yesterday - I pulled the carb today to see if it needed rebuilding.All was good,but someone had been into the carb & reversed the tan colored pump diaphragm.I put it on the correct way,but still the saw wouldn't fire up.I remember yesterday when I checked it for spark that it'd fire with a yellow spark & then turn blue.I'm thinking that the ignition module is breaking down & won't fire under compression..I'll get a new module & put that on & see if it makes a difference.
