POULAN The Official Poulan Thread
Mycamaro_68
By guess and by golly
4:21 AM
Cedar Rapids, IA
Hey fellas, I picked up an old PP P40 and I’m looking for the little rubbers that go in the fuel and oil caps. Anyone know where I might get some? Thanks for any help!
Do you have a picture of the saw? It might help in identifying the parts you need. I definitely don't know all the Poulan saws but I have never seen a Poulan P40. Maybe a Pioneer P40?
cowroy
5:21 AM
Tennessee
I’m sure it is a P40 Pioneer, but pics will absolutely help. Last pic shows the little rubber piece I need.
Maintenance Chief
5:21 AM
South Carolina
Thats the same check valve used in Holley carburetors,(accelerator pump) O'Reilly should have them in their high performance section.
fossil
5:21 AM
Ontario, Canada
That's a weird one . It looks like a P39 Plus.
Maybe when they moved production to Huron Park they got the labels messed up.
You might check the Stihl check valves for an 036 1110 353 1600.
If you want to measure the ones you have for diameter of the valve and length of the tail I can check one on my 036 to see if they are the same.
mirage
3:21 AM
idaho
Can anyone give me any info on this starter. I can find a model # anywhere on the sawimage.jpg
mirage
3:21 AM
idaho
fossil
5:21 AM
Ontario, Canada
4:21 AM
mirage
3:21 AM
idaho
anyone here try and change the fuel lines on a 361? What a PAIN
mirage
3:21 AM
idaho
Anyone know where I can get crank seals for a 361
mirage
3:21 AM
idaho
fossil
5:21 AM
Ontario, Canada
I have a list that shows,
SKF CR7414 seal for the clutch side 0.75 in shaft X 1.124 in OD X 0.188 width. Either one will work.
For the flywheel side, SKF CR6119 (with dust lip or SKF CR6120 (sealing lip only) 0.625 in Shaft, 0.875 in OD, 0.188
It's always a good idea to use a vernier to measure the crank diameter where the seal rides and the diameter of the case pocket in the saw before you buy to make sure the dimensions match the above.
mirage
3:21 AM
idaho
Thank you AGAIN Mr Fossil for that seal I fo.I will go look for them right now and get them ordered.
