fossil
- 2:39 AM
- Jan 1, 2016
- Ontario, Canada
Hi all,
I have a pp4620avx and I'm looking for an IPL for the carburetor. I have google'd several diagrams but nothing with the part numbers and descriptions. I want to take the carb off and give it a good cleaning. I also want to know how to adjust the carb. I know that these saws aren't thought of very highly, but it is perfect for what I need it for, which is the occasional cutting down smaller trees and cutting wood gifted to me to cut up then split for firewood.
tia,
s4l
It should have a Walbro WT-657. Here's an IPL from Walbro.
The setting for the carb should be set as the following and then tune form there.
Low idle mix needle (the one closest to the intake) 1-1/2 turns out from lightly seated.
High speed mix needle (the back needle) Start with two turns out.
Link to IPL https://walbro.force.com/Store/ccrz__ProductDetails?sku=WT-657-1&cclcl=en_US
Not a bad little saw. If you treat it gently it should last for years.
