rocketnorton
- 9:24 PM
- Jan 21, 2016
- surrey, bc, can
anyone know of 4000 af available?
Thanks a lot Brother, lil red barn has piston and rings. Maybe cylinders too. Need paint that is plastic compatible. Think I will get a set of 3400 decals.That line of saws typically have pretty low compression. Squish on those is usually about 0.040"
If it's at 140 psi I think you're good to go. It will run strong at that number.
Aftermarket seals for those are SKF CR6119 and CR6120 as well as National 253747. The National seals tend to have a case diameter a little more than .001" larger than the SKF seals and can be tougher to seat.
National is now owned by Timken.
The bearings are BH-108 full compliment drawn cup needle bearings. They tend to be a bit sloppy and most I've checked (new and used) have a radial play around .005".
I can PM you a link to a good repair manual if you want.
I don't know what a af is. Air filter?
Whats your thoughts on this pulan. Were they any good? Specs say 60 cc.![]()
Ya for sure. I got a busy week this week but might find time to see about it lol.I have the 54 cc version which is a 336. It's a great saw. I figure the 365 wouldn't disappoint.
Maybe if you buy it you can bring it to the GTG in Aug Randy.
That makes sense... sometimes my brain doesn't really think things throughThe engine paint section of the auto parts store is a good place too look.
Hey Steve,I would say try the Low speed at 2-1/2 turns out like you found it and go from there.
