POULAN The Official Poulan Thread
Thesandman
5:54 AM
Mid michigan
That line of saws typically have pretty low compression. Squish on those is usually about 0.040"
If it's at 140 psi I think you're good to go. It will run strong at that number.
Aftermarket seals for those are SKF CR6119 and CR6120 as well as National 253747. The National seals tend to have a case diameter a little more than .001" larger than the SKF seals and can be tougher to seat.
National is now owned by Timken.
The bearings are BH-108 full compliment drawn cup needle bearings. They tend to be a bit sloppy and most I've checked (new and used) have a radial play around .005".
I can PM you a link to a good repair manual if you want.
Thanks a lot Brother, lil red barn has piston and rings. Maybe cylinders too. Need paint that is plastic compatible. Think I will get a set of 3400 decals.
fossil
5:54 AM
Ontario, Canada
Better still, you need a paint that is fuel resistant. Most rattle can paints will blister off if gas gets on it.
You can use a spray enamel and coat it with an enamel clear coat.
The best one I've used is
PlastiKote Engine Enamel, Product #229 clear
Thesandman
5:54 AM
Mid michigan
Thanks for all your help Fossil. I'm going to try to get everything around prior to starting. Never did this before. Hope to make a quick project out of it.
Saw Collector
OPE Member
5:54 AM
Here
Hello fellers. Does anyone have a NOS, or used but known to work correctly, oil pump for a poulan 20D saw? Preferably the one with the manual option. Thank you.
merc_man
merc_man
5:54 AM
southern ontario
Whats your thoughts on this pulan. Were they any good? Specs say 60 cc.
fossil
5:54 AM
Ontario, Canada
I have the 54 cc version which is a 336. It's a great saw. I figure the 365 wouldn't disappoint.
Maybe if you buy it you can bring it to the GTG in Aug Randy.
merc_man
merc_man
5:54 AM
southern ontario
Ya for sure. I got a busy week this week but might find time to see about it lol.
Be a nice addition i think.
Mycamaro_68
By guess and by golly
4:54 AM
Cedar Rapids, IA
I finally got ahold of a 5200! I'm super excited! Any of you guys know of a satin black spray paint that will hold up to gas? I need to get the top cover painted. Hopefully tomorrow I will get it in some wood to get it tuned well but seems to run great!20210526_181344.jpg
jk14
5:54 AM
Glenside Pa.
Looking for a top cover, air filter cover and air filter for a poulan pro 305/335/3300 etc. Does not need to be pretty just functional. Here's what I'm working with.
countryhog
BTDT
4:54 AM
NW Arkansas
Any of you guys ever split the case on a poulan 2000? SM says no gasket but calls out a poulan liquid gasket. Ya suppose motoseal will do the trick?
S Sidwell
5:54 AM
Georgia
That or Hondabond
Steve from my moto g(7) play using Tapatalk
countryhog
BTDT
4:54 AM
NW Arkansas
Got it split, cleaned, and reassembled using motoseal. Probly pressure test tomorrow. We’ll see.
CrystalRiver1
4:54 AM
Alabama
I would say try the Low speed at 2-1/2 turns out like you found it and go from there.
Hey Steve,
Have you ever did a muffler mod or ported a Poulan 5020?
Just curious a guy has one for $50---hasn't run in two yrs he says...:rolleyes:
