RickZ
Active OPE Member
- 8:02 PM
- Sep 28, 2019
- New Mexico
The guy didn’t know anything about it. He had found it in a storage unit he bought50 bucks!![]()
Yes you can or slightly file the husky mount, I have a few husky 50” cannons for my MacsHey Mac gurus.... I have a customer who wants a longer bar on an 895 Mac...I've read that a lot of guys adapt large mount Stihl (3002 mount) to these with spacers...Is this a good way to go?
I'm too far away from the guy to do my own measuring on the saw
I have large Stihl bars, and haven’t made the adaptors, but like the husky mount it’s a little narrow at the tail, but not much, I have mac mount 41” cannon and the tail isn’t much different, I can take some pics when I get homeThanks for the reply! Is the wider tail on the big Stihl bars any better? Obviously the Husky must be wide enough for oil hole alignment if that's what you've used
Here are some picsThanks for the reply! Is the wider tail on the big Stihl bars any better? Obviously the Husky must be wide enough for oil hole alignment if that's what you've used
Do you happen to have a picture of the wiring on the 3-10E? If it is really similar it could let me know what goes where. Everything is disconnected so I don’t have any idea where things go. I would really appreciate it if you do, when you have time of course. No rushI just looked at my micro fiche slides and found 3-10 E but not 5-10 but might be similar .I get up real early in the morning,like 4:30- 5 AM .I'll get on it before the rooster crows .In the mean time you might be able to epoxy the brush holder with something .
I do not have a wiring diagram .The picture is unclear what is or might be attached and where but I assume under a screw on the brush holder .You might try a continuity check to see if one brush might already connected to ground .If the other doesn't show continuity to ground it should the where the hot wire goes .BTW I have never seen the workings of a battery start saw,Mac or otherwise if there ever was another company making them .Keep in mind this is all for naught unless it has s a working battery which would be highly unlikely being over 50 years old .Do you happen to have a picture of the wiring on the 3-10E? If it is really similar it could let me know what goes where. Everything is disconnected so I don’t have any idea where things go. I would really appreciate it if you do, when you have time of course. No rush
Thank you so much everyone. I was lost and couldn’t find anything online, so I really do appreciate it. I have looked on this forum for info on my other saws in the past and had a feeling this was the place to ask.
Just got a notification on this saw up in WI. Is it 3-25, or what is you alls thinking. Wish my buddy hadn't moved, and this guy wouldn't have stripped it.![]()
