Duke Thieroff
Fill your hands you SOB!
5:59 PM
Beaver County, PA
heimannm
4:59 PM
Dike, Iowa
With the bridged exhaust, there are no locating pins for the ring ends so they will most likely migrate as the saw is running. I try to orient the ring ends away from the ports when assembling a saw like that, but I don't know how long they stay were you put them.
Mark
the 28inch mac man
5:59 PM
Southern NH
Maintenance Chief
5:59 PM
South Carolina
Not sure what the confirmation was for "great compression " was ? But I have a different idea of what it is.
Would likely assume that with this ad I would at the very least be able to save the cylinder, you know what the old saying about "assuming " is though....
the 28inch mac man
5:59 PM
Southern NH
We got to find someone that can re-plate cylinders.
Max the Mac Man
5:59 PM
Middlebrook Virginia
I wish you the best with that. Been looking for 3 years now in both the US and Canada. US Chrome will do them again now but only in lots of 10 of the same cylinder and only if you have them blind bored before you send them. By the time you get done you are right at $400 in each cylinder door to door, maybe a bit more with shipping to the machinist, then the US Chrome WI, then to US Chrome in New England, then back to you.
Max the Mac Man
5:59 PM
Honestly I bought a PM 570 awhile back. Was told it ran, it did (not great) Told it had good compression (it did 155psi).After a carb kit and fuel line, it still ran like crap. I ended up tearing it all the way apart. Cylinder was flaking badly and top ring was broke. I was shocked it had that kind of compression in its poor state. It wasn't quite as bad as your 850 though. I look at buying used chrome jug saws now like gambling, sometimes you win sometimes you lose. I hope the next one is a winner!
heimannm
4:59 PM
Dike, Iowa
The first one I put together with a sleeved cylinder would run/cut for 90 seconds then die for lack of compression. Once it cooled off compression would come back up to 130+. Run another 90 seconds and die @ 90 PSI again.
I will put another together soon to see if that cylinder was a fluke, or if there is something inherently amiss with the sleeved cylinders.
Mark
