heimannm
11:44 PM
Dike, Iowa
I assume you are talking about the duckbill valve in the fuel cap in your last post PN 53766 ?
Knightmax has them, I have them, and you can usually find them on eBay.
Remove the capillary seal, clean out the pocket with carburetor cleaner and a cotton swab, and be careful when you press the seal back in that you don't knock the center out of the fuel cap. I made a little tool to support the cap when I press the seal back in place.
Mark
Sloa
11:44 PM
Canada
Once again I thank you gentlemen for answering what must seem to you to be obvious. I have two caps but only one vent right now. Both have been cleaned out. Older style cap allows cleaner through brass filter whereas the 797 cap holds with no leakage.
Thinking in this instance I would want leakage as there needs too be air flow but not sure.
heimannm
11:44 PM
Dike, Iowa
That sintered metal plug (or capillary seal) is supposed to breathe so if you have one that is completely plugged, you need to soak it in carburetor cleaner or run it through an ultrasonic cleaner to open it up before using it.
Pop that plug out, install the duckbill valve with the lips pointing towards the tank, and press the plug firmly back in place once it is clean.
Mark
Sloa
11:44 PM
Canada
Mark
Pretty painless all said, really cleaned it up. The brass filter has Quite the patina on it. Letting it soak in cleaner. Small film of moto seal around lip when I replace and let set.
hacskaroly
2100 Fanclub Member
9:44 PM
Northern Idaho, Ehh
Free shipping if you spend $60.00 or more on items shipped in the USA.
Lol, with chainsaws...that is easy enough to do!! I have bookmarked the site, definitely stuff for my 10-10s, will have to look at the other gaskets to see if they will work with a D44 or 200. Thanks for the link!
the 28inch mac man
12:44 AM
Southern NH
For McCulloch Lovers.....
Holiday special for the month of December!
www.oldsawshop.com
Thanks,
Brian Genrich
Old Saw Shop
Thanks man! I will deffenatly be making use of it! Your gaskets are the best around. It nice to see the air box seals and oem style chip guard on the market again. Thanks for supplying all the great mac products!
NZsaws
4:44 PM
New Zealand
www.oldsawshop.com
Thanks,
Brian Genrich
Old Saw Shop
Howdy
Was looking at a PM80 decal today.
Has postage as $60 USD, is there an economy way of sending a decal to the bottom of the world (NewZealand)?
Thanks.
the 28inch mac man
12:44 AM
Southern NH
Howdy
Thanks.
$60 sounds high for shipping a decal. I have had larger things shipped from Europe for less than that.
