Squareground3691
- 7:08 AM
- May 1, 2021
- New England
50” 7 pinNow I have to decide, used 76" hard nose bar, used 50" sprocket nose, new 40" sprocket nose, or new 54" sprocket nose bar. What length would best suit a CP125 in NorCal? .404 is a given, fyi.
According to the mapping the Jacob and I have done, the sp125 has the lowest port timing and highest compression, and the sp125c has the heighest port timing. the cp and 797 have the biggest squish and lowest compression.What makes a 797/CP125 block mo' betta? Aren't they all the same displacement?
The 797 standard has nearly identical cylinder to the mc101, minus the removable head. But the mc101 is also the only 101 motor that way, the 101a, 101aa, 101b and 101d all are ported more aggressively and allmost ported the same as each other, with the 101a being a little bit of a transition motor, that may have had a hand port to the exhaust in early cylinders.I'm certainly no expert but have heard the 797 block was closer to the 101 kart engine than any other like a 125 .Mention was made by the California crowd the round mufflers are a better choice than the later used on the 125 . In the glory days of two cycle go-karts about a zillion companies made parts .Where they all went heaven only knows but it has been upwards of 40 years ago or more . The proverbial needle in the hay stack .
With some work any of the removable head Mac’s have potential….Actually I only have two old Macs with removable heads . One is a super 44 A which for it's age is quite impressive .The original air vane governor has been removed so it runs full open now .
The other is a super 44 that Dan Henry sent me and it's frozen up .It's kind of a back burner project to first toss it in a bucket full of kerosene for a month then get it apart .Then soup it up and put the engine into the shrouding of a 250 with a pipe to change it to a vintage hotty . I don't have any delusions of grandeur on how it might do just thought it would be an oddity ,something you don't see every day but it might surprise me if I get around to it .
Dan also sent along a couple of 5 gallon buckets full of old Mac parts and one part is a brand new unused flywheel that might work to change it to left hand start . I used to talk with Dan a couple times a year and have no idea what has became of him lately .
Is the cylinder painted? Unpainted cylinders are usually replacementsOk, ive got a 82cc mac question. Last week i sat down after work and started a random search on ebay and just listed as a buy it now for $140.00 was a "mcculloch sp80 engine". I looked the pictures very briefly and hit the button! I got it today. Checked it over and thought hmm, looks pretty good. Decided it best to take it apart to see all the spots inside the cylinder and found a pretty darn nice cylinder!! Very nice actually. Great chrome, no scratches scores or peeling anywhere. FANTASTIC. So i looked at the piston and it had a lot of carbon on it. A lot. Cleaned it all up and found the 87791 number on top which i was looking for. Sp80 piston..check. bearings are good, seals are actually tight, the crankshaft has key ways on both ends which i found differdnt for the 82cc saws. No big deal. Oil tank is clean and i basically need to get it back together and make a decision on this one. But ive got a question to the more knowledgeable, this cylinder is set up for a points system only, no visible letter, correct piston for a sp80 however it has the bridged transfers?? Did the sp80 ever have that? I know the early sp81 had the open transfer and sp80 had that feature also, but ive not read of a sp80 having the later sp81 bridge in the transfer??? Makes me wonder about this one a bit. I think i have a sp81 cylinder but would like more thoughts. Also did a sp80 have a keyed clutch? I think thats a little peculiar. Any thoughts are welcome on this. Thanks vinny
Gotta get 'em when they're young Mark.otherwise it's a lost cause,Lol.I received a big box of 600 Series parts from Knightmax a couple of weeks ago, finally got around to getting the out of the box and cleaned up. My grandson "volunteered" to help...
For 14 years old he was very diligent about getting the parts clean.
Mark
