edju1958
- 10:01 AM
- May 23, 2018
- Western N.Y.
I finally got the long awaited PM55 today.Everything on the saw WAS seized - recoil ( needs to have the pulley replaced),engine,manual oiler,& choke.There was no plug in the engine which most likely contributed to the engine being seized.I sprayed some Deep creep in the plug hole & let it do it's magic while I fiddled with the recoil.Lots of white death on the screws & the pulley,the pulley is shot.A lot of folks would've just thrown the recoil spring right out in the trash,but I'm gonna try to save it.The spindle wouldn't even turn after I pulled the pulley off.Surprisingly the plastic bushing is still good.The coil wire is gone,so I've gotta either make a new one,or use a new one I have on hand.
I got the choke to work freely with Deep Creep & a bit of light hammering.After I was done cleaning up the recoil housing I put a breaker bart & socket on the flywheel nut to see if it'd break loose.The Deep Creep did it's job,I could've turned it over with a ratchet.It seems to have decent compression,but hard to tell when turning it over with a ratchet.The manual oiler is freed up,but not pumping any oiol.I'll have to take both oilers off & go through them,my guess is check valve issues.
This saw has been sitting for many yrs.in a not so friendly environment.I hope to bring it back to it's former glory & give it to my son.
One good thing is the fuel tank is in great shape.Here's a pic of the recoil pulley.
