Dream
- 12:22 PM
- Aug 27, 2018
- Elberton, GA
Yes Sir.I think what happens on the horizontal 10 series engines is because they have a bottom exit exhaust .Some mufflers have a curvature in the bottom and some it just hits a sharp bend with no curvature .
In the later depending on the design they could make another bend on the outlet .Combine that pizz poor design with the fact they use an impulse operated oil pump that will in some degree suck chain oil into the crankcase .This pyrolites, effectively turning into petro coke which chews up the exhaust side of the piston in time .The air filters aren't the best design which works on the intake side .
The best of those mufflers are the ones with a curvature with large baffles and no second curve .The worst are those square things with screens .If you want them to run omit the baffles and wear ear plugs,you're going to need them .Then just about like every McCulloch you have to tune them just a wee bit rich . BTW you have to knock the sawdust off those filters more often than a more modern saw .You get passed all that a 700 is a pretty dependable saw with plenty of power .
I love the 10 series. They seem to be the best built and most user friendly of all that ive run. Also best torque or what I call "grunt" in the cut. Seems like They get through faster than some of the modern saws because they dont stall if you need to Dog in a bit. Have a friend with a 372 XP. Let him stump a pine with the PM700. He was impressed by how it went through, even with dogging it hard. Used all of the 28" bar and full comp chain to get through.
I understand what you say about the muffler. That one has the power reed muffler. The reed broke long ago I assume. It does seem to have a curve at the exhaust port, bit id like to modify the second section and just dump it toward the grass. Need earplugs anyway.
Wish there was a simple way to put on a better filter.
