karrl
- 6:10 AM
- Sep 16, 2021
- Sussex County, NJ
I am going to put some in the fall, if that is correct for zone 7. Any tips for growing or planting?View attachment 382530View attachment 382531
More Garlicky goodness. Anybody thinking about putting some in should go for it, takes a little figuring out but it’s relatively low input compared to strawberries or cukes or other delicate plants
We have good luck with planting the purple hardneck variety in mid October, spaced about 6 inches apart on raised black plastic mulch beds. If you don’t want to mess with plastic or a black weed barrier then I would recommend trying to raise your growing beds up to help with drainage. Weed management is important They like a little fertilizer in the fall and more in spring but you should stop feeding and watering them a week before harvest.I am going to put some in the fall, if that is correct for zone 7. Any tips for growing or planting?
Thank you Karrl, that is very informative. I am going to try it this fall after reading about where most of the garlic sold comes from and how it is produced. Now i won't eat garlic unless I take it out of the clove.We have good luck with planting the purple hardneck variety in mid October, spaced about 6 inches apart on raised black plastic mulch beds. If you don’t want to mess with plastic or a black weed barrier then I would recommend trying to raise your growing beds up to help with drainage. Weed management is important They like a little fertilizer in the fall and more in spring but you should stop feeding and watering them a week before harvest.
With this rain and humidity we’re just getting it done but you want to keep them them dry and in a dark place with the air moving once you pull em. Slow drying is the goal. Oh and I’m all about the hardneck garlic over softneck so if you’re looking in your seed catalog I’d point you in that direction
Just use the hammer on the floorThink the clutch just went out of my 1486 I bale w. It’s been adjusted but I think I’m out of adjustment gotta see what’s happening to her here. She’s getting fixed
View attachment 382441View attachment 382442View attachment 382443
Cut a little maybe 400 bushel
We are lucky. We have a little guy 2mi away and he’s a damn good mechanic. I’d you pay cash he nocks some off of laborIn town here is Hoobers. I hate them. They charged us 10000$ yes ten to fix a hydraulic leak. In no way shape or form do the hours add up for labor. Bunch of crooks. I’d rather pay the ride for the old girl up to a “little guy” fixing up old tractors.
If combine breaks down in field I’ll deal with local but there’s just no honest big work mechanics local these days.
Go Masseythere are quite a few older tractors out and about in republic of ireland I’ve attached a graph of tractors registered
with the Irish Driver vehicle Licencing association
View attachment 382519View attachment 382518
How much you charge to send some to iowa?Garlic Harvest 2023, halfway done and we’re already running out of drying area. This wet weather is sub optimal so we’ll have to move these again and separate em a bit. 2/3 weeks and we’ll be all cured.
View attachment 382515View attachment 382516
It’s almost too ready but I’ve only found a few split bulbs here and there so we’re just in time. We chopped some tops off to cut back on the moisture and help them dry.
Cut the top off then lay on a cookie sheet and drizzle olive oil over top of them and bake in oven at 350 until soft then spread on toast like butter. Goodness meThank you Karrl, that is very informative. I am going to try it this fall after reading about where most of the garlic sold comes from and how it is produced. Nowmi won't eat garlic unless I take it out of the clove.
And Tennessee.How much you charge to send some to iowa?
Delaware alsoAnd Tennessee.
Hate horse nettle, everything is supposed to have a purpose, haven't figured out what its purpose is. Other than to drive me nuts. I won't spray here. So mowing is all I got to keep it in check. I also don't have hundreds of acres to deal with.View attachment 382644View attachment 382645View attachment 382646
12 hours after spraying weeds and briars are feeling sick. Well worth having this done.
Take that weeds!View attachment 382644View attachment 382645View attachment 382646
