- 2:47 PM
- Dec 31, 2015
- East Jordan, MI
I’d blame the greasy fingerI miscounted. Had 51.
Bearing gave up the ghost on the starter roller yesterday. So after work headed to dads and finished tearing it down. Easy fix if he can find where the chain is this morning, otherwise he will pick up a new one when he gets bearings. Part of it, things break in hay season.
The guys that put up 2000 plus bales a year have gone to keeping count on the balers year to year, and when they get close to 12,000 bales, they trade em in and get a new one.Bearing gave up the ghost on the starter roller yesterday. So after work headed to dads and finished tearing it down. Easy fix if he can find where the chain is this morning, otherwise he will pick up a new one when he gets bearings. Part of it, things break in hay season.
We only have 5-10 acres of land that could ever be used to make hay/pasture, so unless I buy some land just to grow hay on it I *should* be fine with my 45hp tractor. At some point I'd like to find someone that can upload the 60 HP tune, but that's not something I *need*.I started out with a small tractor, and a sickle bar mower. Then I wanted a disc mower...and a bigger baler. So I needed more horsepower....
Problem is that compact tractors do not have the good old low end torque because of their small displacement turbo engines. Also keep in mind tractors are rated differently now. Your 45 hp tractor is 45 brake hp. Not PTO HP. The tractor I use for hay making is a 45 HP tractor but is rated at the PTO. If I get in some real heavy grass with the haybine you can hear it work. Same with a full bale chamber going up a good grade. Your tractor may be anemic to pull a 3000lb implement as well as drive it too.
also need to remember about weight of the tractor when pulling something and ability to hold it back going down hillGood point Steve. My little tractor is a John Deere 1120. 51hp at the pto.
Also another good point often overlooked. My 45hp PTO tractor is just under 6k so I'm good there for my equipment. My 40 brake hp tractor is 2700 with a loader and 4x4!
I didn’t want a compact being that I have the little Massey
I think it’s about 11000 pounds with loader and 7 foot brush hog
Has wheel weights inside and out the rear centers that are solid and rear tires are filled
it’s a category 2 hitch but yes it is supposed toNice rig! Does that quick hitch require bushings?
But on the brush hog and box blade fits good without them
