The mighty stihl 064 and early 066
MG porting
7:05 PM
Wa
Flywheel question. I am building an 066, it is a total restoration (powdered the case, new tank etc.). It is a short case but is has a big end crank bearing. I was looking on the 064/066 thread that @Definitive Dave made about coils, flywheels and such.
It had listed that the 1122 400 1214 was for a big end bearing. I bought a 1122 400 1209/1214 and it's too small. Is there a flywheel that has only one set of numbers on it, (1122 400 1214)?
Or do I need to just go with a 660 poly flywheel?
If it has the bigger flywheel end crankshaft then you need to get a poly flywheel or a after market flywheel.
MG porting
7:05 PM
Wa
jacob j.
Only the weird
7:05 PM
Coastal Oregon
Ok gotcha I just wasn't sure on that. I figured that I may have to go with a poly flywheel. I think the reason that it doesn't have the right crank in it because I was told that this was a former JMSSAW.
I got a non-decomp jug for free, it had some transfer on it and I was able to clean it up. Checked the squish to see if I could do a base gasket delete. Well it came in at .010" so I had to add a base gasket and if I remember correctly it took it up to .018?
018" is about as tight as I would run it. I have an aftermarket flywheel I could send your way that would fit that crank, until you can source a poly.
blacksmith
10:05 PM
central PA
Thank you for your offer I have an aftermarket one that was on it when I bought it, I just wanted to make sure that everything was updated and OEM. I can get by with the one that I have till I scrounge up enough cash to get an OEM one.
blacksmith
10:05 PM
central PA
Looking for some opinions on this option.
I have a 1122 400 1209/1214 flywheel that the bore is too small. I have a friend that is a good machinist and has all the necessary tools.
Open up the original OEM flywheel to fit my saw.
Let's hear it. Stupid idea or no?
K Mueller
6:05 PM
Alaska, USA
I have a 1122 400 1209/1214 flywheel that the bore is too small. I have a friend that is a god machinist and has all the necessary tools.
I vote find a poly flywheel
10:05 PM
Funny I've never thought of putting ether one on a scale.:BangHead:
Lol if you thought the saws themselves then no, meant just the flywheels. I think a lighter flywheel seems peppier/revs quicker and a heavier one seems to help torque with a big bar. At least this is what I found with other saws.
MG porting
7:05 PM
Wa
Yep there snappy with the poly but with the metal flywheel they carry the torque better underload with the bigger bars it's all in what you're looking for me I prefer torque but every one has there own thing.:beer-toast1:
Deets066
AKA Deetsey
10:05 PM
Poly flywheel can’t be expensive
jacob j.
Only the weird
7:05 PM
Coastal Oregon
I thought I'd show you guys this - I bought this parts saw from a member here, it's an original 066. It's vintage circa late '93/early '94. The case has never been cracked open.
Over the years I've mentioned that Stihl used sealed bearings from the factory for a short time - here's the pudding:
10:05 PM
I wonder why they did that? Seems contradictory, probably why they stopped doing it?
10:05 PM
Shouldn’t be any different than any other sealed bearing
In a chainsaw, it seems like you’d want the crankcase side of the bearings to be exposed to fuel/oil mix to get lubrication under hard loads running hot. Seems like they would be getting less with that side closed off?
