markds2
- 9:15 AM
- Jul 22, 2018
- Nelson, New Zealand
I did it on a 261, which was a different part number I believe. It’s been said that it wouldn’t work, but it did for a few of us that tried it. I can’t say with any certainty that it will work with a 661 as I haven’t tried it@huskihl , was the kit with the coil, solenoid and filter? 1144 007 1801?
It looks like I can't use the white solenoid with the 4701A coil...
Thanks Kevin.I did it on a 261, which was a different part number I believe. It’s been said that it wouldn’t work, but it did for a few of us that tried it. I can’t say with any certainty that it will work with a 661 as I haven’t tried it
work(S) for me...every time so far. i just do both resets...cause i cant remember which ONE is correct.... so do em both.Thanks Kevin.
@angelo c @sawmikaze @Redbull661 @redlight066 can any of you say for certain that the white solenoid will work where a black one has been taken out? On a 661C with a 4701A coil...
Thanks Angelo, that is exactly what I wanted to hear. The black solenoid is the same price as the white here in NZ and both the 1140 007 1802 (Solenoid and filter) kit and the 1144 007 1801 (Coil, solenoid and filter) upgrade kits are out of stock with Stihl NZ at the moment.work(S) for me...every time so far. i just do both resets...cause i cant remember which ONE is correct.... so do em both.
Thanks Kevin.
Thanks Ryan, appreciate your input. Unfortunately neither kit is available at the moment - out of stock here in NZ.It works. Buy the kit that includes the orange filter with the solenoid.
Do the old reset with the coil you have, I don't feel like typing it...look in Julian's thread.
Or..if you end up with the kit with the V3 coil look up the procedure on that, it's different. And it runs a little richer with that coil. Better for a worksaw.
Stuck with buying the white solenoid and Orange filter individually...
