hseII
Heef
- 8:40 PM
- Dec 29, 2015
- West Georgia
Demanding customers...
Ewe No It.
The Mtronics saws deal with timing advance different than the older carburetored saws? These quadports too?
Ahh. OK. Thank you.The mtronic saws adjust timing and fuel based on feedback, the quadport 361 is just a coil with a curve like your saws Jeff.
Fair enough, Sir!Because advance helps throttle response. Adds zip, but not always overall decrease in cut times. Even with increased compression.
Most saws like it up to a point. This saw may already have more initial and total advance dialed in from the factory than the older models I generally play with.
I also asked many experienced builders here that have modded it before if it benefitted from a timing advance. They all said yes.
Where do you people keep getting pictures of me?
Dan,The mtronic saws adjust timing and fuel based on feedback, the quadport 361 is just a coil with a curve like your saws Jeff.
Dan,
Im not sure the electronics have a mechanism to advance or retard timing. I believe it can only adjust fuel flow based on a few parameters. boy electronic ignition would make these toys funner.
Just enjoying a build thread.I leave out the lower ring Doc. That allows me to use my spinny thing in the port.
