hseII
Heef
- 12:34 PM
- Dec 29, 2015
- West Georgia
I like turtles
And Other Midgets.
Don't Forget Them.
Yes We Do.
I like turtles
I like turtles
Cranky old sumbitch huh?Me too.
As a matter of fact, I saved a mud turtle while I was cutting hay. Big old guy. He didn't seem grateful though. Tried to bite me....
That's sumpin' I saved an Eastern Box Turtle from the haybine this year. He was closed up. Later that day, I saw a huge snapper in the middle of the road. It was near a trickle crick, but half a mile from any pond I know of.Me too.
No ideaHow much did you take off the key to have it pop? .20, .25? More?
Leaning out the mixture would make a timing "pop" worse ......... think about how combustion happensAm I the only one that has a hard time discerning between borderline 4 stroking and a timing pop? I leaned it out and it got better. Leaned it out more and it went away. I still don't know if it was just too rich, or if leaning it out actually affects the timing pop too
If that's the case, I was still just too richLeaning out the mixture would make a timing "pop" worse ......... think about how combustion happens
Because advance helps throttle response. Adds zip, but not always overall decrease in cut times. Even with increased compression.Why not just run standard timing?
Curious
Most saws like it up to a point. This saw may already have more initial and total advance dialed in from the factory than the older models I generally play with.
I also asked many experienced builders here that have modded it before if it benefitted from a timing advance. They all said yes.
Demanding customers...Pics of your Initial & Total Advances.
