Sid Post
Active OPE Member
- 7:54 PM
- May 20, 2016
The 16" low-pro guide bar on my MS241-CM has a tip problem causing a lot of drag so it is bogging my saw down. That bar has seen a lot of use and should have a lot of life left but, the tip got pinched felling a tree so I blame myself as much as anything for the problem.
I believe it is 55 drive links so, pretty short IMHO. I spend a lot of time right now in heavily overgrown areas with vines and thin light trees in my way so, I find myself reaching a LOT to clear a path for myself to get to trees that need to be cut. I'm thinking a real 18" or 20" guide bar is the right choice today.
With supply chain and staffing problems today, what are my better guide bar options for this saw today?
TIA,
Sid
TIA,
Sid
