Ketchup
Epoxy member
- 2:08 PM
- Mar 12, 2018
- Colorado
205 psi at 5600’ is in the realm of “too much compression” in my opinion. That would be around 240 at sea level. One of the first saws I did machine work on is a Poulan…that thing blows like 225 at my elevation of 800ish ‘. I haven’t gotten it to run right….some day I will get back to it and fix it.
I think I agree. I don’t really trust the specific number, but it is a bear to start. Usually I can only get it to turn over once on the first pull. It takes a few tries to get it to turn 3 or 4 revolutions. Luckily it pops pretty fast.
Caleb, is there a reason you went with a 54mm big bore cylinder instead of a 52mm OEM one?
I think you have a metric *s-wordton of case compression, so I would want your uppers more numerically higher than usual so that you don’t over scavenge. Pretty much the same thinking as doing a 446 hybrid. Good numbers for a 446 vs a 460 are quite different. I usually want more BD on the 446.
It would be quite interesting to know where your ignition timing is. To reduce compression, you could add another angle in the band up towards the chamber and then hand blend it. I still believe that dishing a piston after the squish band interface shouldn’t affect scavenging much. Even Husky decided to do it on the newer 562.
You have increased heat from all that compression and fin area reduction. The 036 flywheel may be adding to the mismatch. I wonder if the ignition timing is as well.
As you know, stacking gaskets is going to change many things at once. It’s too bad it’s not a 52mm, where you would have readily available slugs to play with. My gut tells me you need more intake and exhaust duration, and the uppers need to come up a bit. I was thinking 99/122/78.
Saw sounds pretty damn good in that last video. Thanks for taking the time to do this.
I did the 54mm for three reasons. Cost, risk and displacement. I know the problems of AM jugs, but in this case I was curious if I could overcome the performance issues. That isn’t clear yet.
I’m pretty surprised by the compression. I didn’t take that much out of the band (0.020”?) and the squish is a healthy 0.022”. These AM jugs have a relatively large chamber. You’re right about the heat. Lucky I didn’t take more fins off.
I think I like the current ignition timing. I haven’t put a light on it but I tried a whole range. The current setting was the smoothest. I want to time it eventually but my instincts say thats not the main issue.
I started conservative with the port numbers. I like 99/122/78. Stacking gaskets should land somewhere close except the intake, so it’s an easy experiment. I could see this saw landing even a little higher eventually. On the 446 hybrids, what is the typical blowdown? 20 degrees?
Raising the exhaust should reduce the compression but I’m not sure if it will be enough. I’ve been experimenting with reshaping some chambers. That would be the next step if I can’t get the compression down. I’m a little biased against dished pistons, but that would be a less permanent option.
Great thoughts fellas. Thanks for all you’re insights.
