Stihl 009L
countryhog
BTDT
6:19 AM
NW Arkansas
my 009 spits bar oil like its the exxon valdez. Does it have a way to adjust output?
jb-chainsaws
11:19 AM
UK
I think it's a characteristic of these saws, the pump from memory works on impulse the same as the carb so if it's running it's pumping!
Homemade
7:19 AM
Wisconsin
How about epoxy in the output hole and just drill it out to a smaller size. You can increase the size of the drill bit until you get the flow your looking for.
But if the tank isn't running dry before you run out of gas, then what's the harm for a little extra lube.
MrWhoopee
4:19 AM
Shingletown, CA
My 009L barely puts out any oil at all. The shop I bought it from "fixed" it twice with no change. Any suggestions for me?
cus_deluxe
terms of service violator
7:19 AM
Michigan
This, uses a little diaphragm and plunger riggin', i dont believe its adjustable but i could be wrong. Feel fortunate yours works i guess haha!
cus_deluxe
7:19 AM
Michigan
The ones ive seen the diaphragm material has been disintegrated and no longer pumped.
