jmfcst
Active OPE Member
- 4:35 AM
- Mar 15, 2025
- Houston area
Hello forum, first time poster...original owner of absolute bullet proof MS260 Pro...I have only done very basic maintenance over the years: air filter, fuel filter and lines, exterior cleaning of saw, new chains, etc....
It is burning up new bar and chains just by revving, in fact it is melting tips chain linkage (side which rides in groove of bar) and blue-ing bar...verified correct bar and chain for 260 pro model...chain is not overtightened...took bar off, oil is coming out of oil port when revving engine...but when bar (old or new) and chain is installed, saw is barely (I mean barely) spraying oil, *BUT* oil is dripping to the ground from sprocket area *AND* oil is being used at same rate as fuel....bars (both old and new) are 100% perfectly clean including oil ports....so oil is making out of saw port and into bar port but is not being sucked onto the chain.
Is this an oil pump issue?
