conscons
OPE Member
Today, rock bolts are in widespread use throughout the underground mining industry, as well as being used in the civil engineering and tunneling industries. Rock bolts have played a major part in the improvement of roof conditions for the mining industry, and hence have improved productivity and efficiency. Nevertheless rock bolts are used in the harsh mining environment where there are often difficult ground conditions, and rock bolts can be subjected to high stresses, and sometimes also with corrosive groundwater conditions. When the stresses on the rock bolt exceeds the strength of the bolt, then rock bolt failure does occur.
Stainless rock bolt is made of stainless materials, which has higher intensity and broader applied conditions. Good capacity of welding and anti-corrosion determine that anchor bolt can suit for special construction conditions, such as undersea tunnel, harbor and also many others. Sinorock is an experienced manufacturer of anticorrosion rock bolts, offering not only high quality stainless rock bolt, but also duplex coating rock bolt and ordinary rock bolts that in R-thread or T-thread. As a leading manufacturer in this industry Sinorock can meet clients’ exacting demands for critical applications in hostile environments. Whether for offshore (buoyancy and petrochemical), seawater, pump, tunneling or mining, the demands for an exceptional service and supply is never ending.
