squish bands
Brush Ape
Direct Connection
10:21 AM
Metropolis, Il
It's not crucial in a 50cc saw. How much difference could an angle make across that short percentage of the piston diameter? It was just to raise the compression 15 points.
Windthrown
GFY Certified!
8:21 AM
The Cascades
Wow, I have only been on this site for 10 minutes and I already have someone to add to my ignore file.
Redfin
Meh...
11:21 AM
Central Pa
I believe that to be true in larger bores
Are the bands in larger bores about the same size (percentage of the total) as the ones in smaller bores?
Edit: maybe i should have said motorcyle or sled cylinders compared to saws.
Windthrown
GFY Certified!
8:21 AM
The Cascades
Did you sign up just to say that?
Er, no... I was not aware that BA was here when I signed up. I was wondering where he was spending his time though. He (or whomever of his multiple personae) seems to like to follow Randy around.
bwalker
11:21 AM
Montana
The band's are smaller in relation to bore size for bike and sled engines.
bwalker
11:21 AM
Montana
As time went by bike heads seem to gravitate toward wider bands at more of an angle with flat top pistons.
GCJenks204
"Special Buns"
10:21 AM
Winnipeg, MB
I think the community would hope you don't rush to judgement on anyone and get to know the person a little.
In this case I have observed a much different person than on AS with an incredible amount of knowledge.
Sent from my SGH-I317M using Tapatalk
Windthrown
GFY Certified!
8:21 AM
The Cascades
Well, I have no interest in dragging this thread off-topic any further, but BA is enemy #1 in my book, for many reasons. Wherever you go, there you are.
tree monkey
10:21 AM
wi
Hedgerow
10:21 AM
if I remember right, there are 3 bores, 2 flat, 1 pop up
That's what I've seen..
The Super I built for the build off in KY had a slight taper on the piston and squish band to match.
I did not cut them.
.019 squish, 112 ex and 195 pounds comp..
All OEM to my knowledge.
It's a runner...
Hedgerow
10:21 AM
about 50% of the bore, bikes, sleds, and saws
Lately, I've been seeing a lot of squish bands cut at way over the old rule of thumb 50% of cross sectional area of bore on saws..
Not sure it's good or bad, just an observation..
