Solo 665 thread
Deets066
AKA Deetsey
5:07 AM
Was gunna run the solo today but timing seemed way advanced, I set it about 1/8 advance. Got the nut off the flywheel (which was plenty tight enough) and saw this
See the shiny ridge at the end of the taper? End of the flywheel was hitting the end of the crank.
I opened her up a little at the end and roughed the taper up with emery cloth, along with the crank. Hopefully it's seats this time.
@Mastermind and @Miller Mod Saws, either off you guys seen this before?
Deets066
AKA Deetsey
5:07 AM
Flywheel fell right off after I got the nut off, never did lock in the taper
Red97
5:07 AM
MI
Can you get a pic of the other side?
Deets066
AKA Deetsey
5:07 AM
This is with no base gasket and .019 squish. Never did check compression either, not too worried about that
5:07 AM
Dolmar 7900 metal gasket is .016-018".
