So what's the current two stroke oil favorite?
mrxlh
I stayed late and finished!
12:58 PM
Dat Boot
That's at 300:1 or something who runs that ratio in a saw. I'm sure at 40:1 most oils are more than adequate for a chainsaw.
Some never made it past the 100:1 testing…….There were also some control tests at 40:1 and 50:1, you would be surprised at the oils that didn’t do very well in that round.
rogue60
4:58 AM
AU
Who runs 100:1 in a chainsaw not surprised at all some oils failed at this.
As for 40:1 50:1 not surprised as well with some performing poorly at that mix ratio in a chainsaw. Some oils are crap yes but it's not my saws it's being run in so I don't pay much attention to it.
1:58 PM
I’ve noticed more differences from using different quality or octane gas. That definitely has a effect. Fresher is always better.
mrxlh
12:58 PM
Dat Boot
100:1, 200:1, 300:1 wasn’t the actual point of the testing, it just morphed into that. It was actually more along the lines of “Is 40:1, 32:1, 25:1 necessary for a saw?” depending on the oil you use no.
Saw Collector
OPE Member
1:58 PM
Here
Nobody. Thats not the point. That said, any oil that can survive 300:1 for hours vs an oil lasting 7 minutes at 200 has a much better protection reserve in its additive package. It it needed? Most likely not, but Its nice to know the oil you run has a much higher quality anti wear package vs many others. At least many of us feel that way.
davidwyby
Rural desert logging
10:58 AM
Extreme Southeast CA
Nobody. Thats not the point. That said, any oil that can survive 300:1 for hours vs an oil lasting 7 minutes at 200 has a much better protection reserve in its additive package. It it needed? Most likely not. Its nice to know the oil you run has a much higher quality anti wear package vs many others. At least many of us feel that way.
I agree. But I also want the Most Powa! (And throttle response…seems I remember red armor protects well but maybe hurts response.
@Red97 !:D
rogue60
4:58 AM
AU
I get all that some guy's want the best even if it's overkill.
The cheap mineral oil I run in my old work saws at 25:1 performs better than a lot of oils and synthetic oils at whatever ratio from what I've seen.
But I know the oil I use would probably be the 1st to fail at 100:1 300:1 even at 40:1 50:1 I wouldn't be very confident it would pass.
But this wouldn't stop me using it. It's a proven oil at that ratio in my saws long term for thousands of hrs.
A lot of good oils could be passed up just because they failed at extreme ratios but perform perfectly fine at normal ratios or even richter oil ratios.
I generally try staying away from going down the rabbit hole when it comes to oils some guy's lose there chit over oil lol
Duce
1:58 PM
Roscommon, MI
What oil works best running underwater? Local tree service dropped a 572xp into Higgins lake while running. Pulled muffler and piston still has machining marks. He only runs Husqvarna XP+ at 50:1, so it must be the best for running underwater.
1:58 PM
Those saws are surprisingly tough. I’ve dropped a tree and a log on one of mine. I’m still using it after replacing the handlebar and brake handle a couple times over the years. Even had water get into the fuel once or twice with no ill effects on the saw.
Dieselshawn
1:58 PM
Southern Ontario, canada
@Red97 !:D
You’re right, the “Most Powa!” requires serious engineering using the most advanced homemade tools and throwing the manufacturers’ EPA stamped, engineered build plans out the window. :D
Guido Salvage
Supreme saw hoeder
1:58 PM
Farmville, VA
I will probably be running Stihl Ultra for the remainder of my life. I found a guy in Kentucky who had bought out all the Stihl stuff from a local Ace Hardware. I bought all the oil he had, $4 for a 6 pack of 1 gallon bottles, $6 for the 2.5 gallon bottles and $8 for a 6 pack of 5 gallon bottles. I still have a couple of boxes of it left.
Brufab
1:58 PM
michigan
Getting ready to pull the trigger on a Remington PL4 any recommendations on oil type? Is echo red armor an acceptable oil to run in a 60 year old saw??? Thanks fellas! Says 1 pint to 2 gal for 16:1 ratio on the saw.
